Old 10-13-2018, 08:50 PM   #1
jhawk19   jhawk19 is offline
jhawk19's Avatar
Fires up, won't stay running.
Hello all,
I just built my Hawk last night. I took today to change fluids (fresh oil, fork oil, brake fluid) and heat wrap the exhaust and finally to change the front and rear sprockets.
I went to fire it up for the first time and it fired right up!! Then it cut off. I can start it with the choke on all three settings, but it won't stay running...it just cuts off after 5 or 10 seconds.
I have adjusted the idle screw counterclockwise a few times, but same results...
What is my next step?
Old 10-13-2018, 09:04 PM   #2
Red Hawk   Red Hawk is offline
Red Hawk's Avatar
How much gas in the tank?
Is the petcock tail end up ?
Fuel line kink free?
I know these are basically dumb questions but it's the small details.
2018 Hawk P&P Decked .040 off the head. 17/43 D.I.D. 428, NGK Iridium plug, DeCat, Wrapped pipe, Custom S.S. Muffler core, Nibbi PE30 115/35, L.E.D. Lights, Digital Cluster, USB port, Cutting Bord skid plate, Oil cooler w/ custom CRF oil filter inline, 5Wt fork oil, Rear Shock, CNC Back Rack, 30mm FAT bars, Bark Busters, ProGrips, Adjustable levers, Shinko 700’s lots of Loctite!
Old 10-13-2018, 09:11 PM   #3
jhawk19's Avatar
1/2 tank of gas...petcock is on...fuel line has no kinks, it's a smooth "s-curve" from the petcock to the carb.
Old 10-13-2018, 09:19 PM   #4
Red Hawk's Avatar
There's a fuel drain screw at the very very bottom of the carb crack it about 2 turns and catch the fuel draining out, it should have good uninterrupted flow.
Not spurts. Flow, spert.
Old 10-13-2018, 09:30 PM   #5
jhawk19's Avatar
Yep, turned that too. I let the fuel drain so that I could remove the carb. I was going to replace it, but decided to run stock for a while before I make changes. Fuel drained nice and smooth until it dribbled to a stop. Tightened the screw and reconnected the carb to get to the point described in my OP.
Old 10-13-2018, 09:37 PM   #6
Red Hawk's Avatar
I'd pull the plug and see if it's wet or dry?
If it's wet it's fouled out. But it's a long shot.
Old 10-13-2018, 09:55 PM   #7
jhawk19's Avatar
I put a brand new NGK plug in today. I'll have to check to see if it's wet...otherwise (if it's dry), anything else I can do? I mean, it starts, right away, first push of the button...
Old 10-13-2018, 09:55 PM   #8
jhawk19's Avatar
Originally Posted by jeffrey View Post
Turn the idle screw clockwise to raise the idle speed.
OOOHHHHHHH!!!! Clockwise!!!! I've been turning it counterclockwise!!!
Old 10-13-2018, 09:56 PM   #9
Red Hawk's Avatar
That might be it
Old 10-14-2018, 09:46 AM   #10
roundhouse   roundhouse is offline
roundhouse's Avatar
Did that fix your problem? When it is cold I have to turn mine a couple turns higher to get it going then back it off after a couple of minutes.
Old 10-14-2018, 03:09 PM   #11
bogieboy's Avatar
If your tank is half full, this is your issue... check your petcock... the way your float works, you should have a constant drain of fuel until the tank runs dry.... you either have a sticking float, or a shoddy petcock... your bike runs fine for a bit because ths bowl fills up, but then you run the fuel in the bowl out and its not filling back up fast enough to keep running...
Old 10-14-2018, 08:17 PM   #12
jhawk19's Avatar
Fixed...thanks guys. The fuel tank was still half empty, but once I turned the idle adjust clockwise, it stayed running at a high RPM. I let it run for about 5 minutes, then I shut it off and adjusted the idle back down slightly. I was then able to start it with no choke and it ran beautifully. I took it for a ride and came home, filled the fuel tank and took it for 3 more laps around my neighborhood with zero issues!
Old 10-14-2018, 08:40 PM   #13
WatchDoc   WatchDoc is offline
Great to know, thank you for this information.
Old 10-15-2018, 07:19 AM   #14
roundhouse's Avatar
Glad to hear it. Sounds like something I would do.
Ran the battery down once trying to start my hawk. forgot to flip the switch on the handle bar............
Old 10-15-2018, 11:29 PM   #15
you can adjust it with it running too
2016 hawk
kaw h1 400 tripple
13' long chopper in progress
2009 johnny pag bar hog
