09-12-2018, 12:17 PM | #1 |
Tire size question
Hey guys, I'm curious why most front tires are an inch bigger. What is the reason for this and what would happen if I put all same size tires? The fronts would if course stay 3 inches thinner. Thanks
2016 Coolster 3150-DX2 |
09-12-2018, 12:38 PM | #2 |
The larger the diameter, the greater the contact-patch on the ground. So, they use a narrower width on the front but make-up for the loss of contact-patch with greater diameter. On dirt bikes, the larger the diameter the better the tire rolls through rough ground/bumps.
09-12-2018, 01:16 PM | #3 | |
Ok, thanks for the response, but would it be fine if the rear tires were the same height as the front tires?
09-12-2018, 01:44 PM | #4 |
Anything is possible. Just know that if you change rear wheel/tire diameter you may have clearance issues and you will change the gear ratio.
09-12-2018, 01:55 PM | #5 |
I run 23" tires front and rear on my Rhino. Works fine.
09-12-2018, 02:50 PM | #6 |
Tires
Some models of bikes and atvs have the same size tires.... manufactures choice???? but you can change them to what ever you want... it is your money... I really do not think you are going to gain much...
09-12-2018, 04:05 PM | #7 |
Cool thanks guys
