Hawk on the track
Hello! Any of you guys take your hawk to a mx track? i ride mine the 30 miles there and rip it out there. The hawk handles the jumps pretty good. I've never had the suspension bottom out on me, and I'll go about 10 feet high.
It is a little rough on the whoops. I've broke my fender a couple times and tank protector there xD |
The weight of the Hawk alone is enough to bottom out the rear shock from a jump, so even if you're a horse jockey or the size of a 6 yr old you'll bottom out. Dual Sports in general are heavier and not designed to take the abuse of a MX track.
2018 RPS Hawk 250cc Mods so far: 1. Mikuni VM26 Carburetor w/#115 main jet 2. 17T/45T JT sprockets 3. JT 428 X-ring chain 4. Air box mod 5. Hawk Digital Cluster 6. Aftermarket IMS shift lever 7. Performance Aftermarket Exhaust 8. 295mm Nitrogen Gas Monoshock, 20W oil front forks |
I can see a bunch of new threads coming ,I bent the frame ,I broke the frame ,I broke the swing arm ,the steering head broke right off the frame so I must have a KTM clone frame,my rims are now flattened ,I got beat by a 7 year old on a yz60 ,and of course the good old “this Chinese bike is a piece of crap because everything is breaking on it “ which will be coming soon .
I would love to see some video of the “rip it out there “ stuff you are doing though . |
I can't remember who it was but someone here raced his Hawk and sent in pics. Pretty cool.
I've broken the the passenger foot peg mount dropping it, broke lots of plastics, sheared the sprocket bolts, ECT.
But I fixed it all. I weigh about 160. I have a tire mark on my muffler, but the rear shock is pretty stiff. I've been out there a couple times. I usually can keep up decently with the 2 strokes. I'm planning to do an enduro or a hare scramble on it this next year. Once I got a pinch flat riding a trail (luckily installed a rim lock) in my front tire, and had to ride it back flat. it has a small dent and i had to true the wheel, but it's true. I've been keeping an eye on the frame, its been holding up. |
Easy Rider Vs Hard Rider
Running a Hawk on a track or a good woods single track smoothly would minimize damage. I did not say slowly cause a good rider could take a ten foot jump at speed and still land it gently. I am not that guy but know some that are able to do such things. My 2 cents worth
![]() 2015 Hawk 250 2006 883 Sportster 2005 1200 Roadster 1972 Honda CT70 Lost along the way; 1982 GS1100L 1983 Honda 185s 2ea. 1974 Puch 175mx Right Arm |
I plan to take mine to desert trails, hills, and small MX tracks.
Q: Do you take the mirrors, lights etc off when you get to the track? I think a picture with the license plate on jumping in the air would be great! ![]()
BaShan BSR 250 DB-41H 2018 Red BS250GY-18D JFG Racing Exhaust . Adjustable Shock 320mm . Brozz Digital Gauge . Renthal Fat Bar . 428 17x46 Sprocket . Fender Eliminator . Wheel Truing . Fuel Tank Repair . Keihin PZ30 Main-115 Pilot-38 Needle-1Washer Fuel Mixture-1/2 BSR Chronicles - "Project leads to more projects!" Yamaha WR250R Suzuki GSX-R 600 |
I do not take mirrors or lights off. I usually just leave them on. The stock turn signals can actually take quite a beating, as can the headlight (more readily wants to pop out than to shatter). I plan to make a headlight protector of some sort after knocking it in the housing a couple times.
I only keep 1 mirror on the right side, I'm planning to switch it for a high quality mirror that will fold in such an occasion. |
I've done a bunch of wheelies on my hawk and nothing broke so far. I can usually set her down somewhat gently. They are tough little bikes. It is not a KTM so I won't be skipping over the crest of whoops, which I probably can't do deep into my 40's. My Hawk is equal to my skills.
I have a go pro that i will take to my next track. ill tape it to my helmet, lol.
