08-07-2018, 04:53 PM | #1 |
Hawk 250 oil leak from silver hole
On my hawk 250 on the left side of the bike there is this weird silver cap looking thing that has two circular holes in in that it looks like u use to unscrew. It's leaking from it. I don't know what it is though.
08-07-2018, 05:38 PM | #2 |
Which one is leaking? if it's the lower one then remove it and check the oring for damage. Or it may just be lose and needs to be snugged up. If it is the one on the cylinder jug, do not remove it. It is the cam follower shaft and you don't want the cam followers to fall into the crank case.
2024 Linhai 300 ATV 4x4 2023 Lifan Lycan 250 Chopper 2023 Venom Evader 2022 Lifan KPX250 2020 Kawasaki Vulcan S (Sold) 2004 Honda ST 1300 2016 Black Hawk 250 (sold) Keihin PE30 carb,125 main,38 slow.Pod filter,ported & decked head 10:1 CR,Direct Ignition Coil,15/40Sprockets,NGK DPR8EIX-9,De-Cat,Dual Oil Cooler,Digital Cluster 2016 Cazador180 XL 2014 Coolster150 JerryHawk250.com My YouTube Channel Last edited by JerryHawk250; 08-08-2018 at 01:29 PM. |
08-07-2018, 06:24 PM | #3 |
It's in the cylinder jug where can I get the tool
08-07-2018, 07:20 PM | #4 |
My hawk has a slot for a flat blade screw driver. Take a picture and post so we can help.
08-08-2018, 07:40 AM | #5 |
Hey does anybody know where to get the after market digital gauge cluster for the Hawk 250? Also has anybody had an issue with the oil filling up in he air box and causing the bike to run like crap. It just started doing this to me and I only have 300 miles on the bike. Before ran like a champ. I was wondering if I should just do away with the air box and put a aftermarket air intake or put a PCV on it.
08-08-2018, 10:06 AM | #6 |
The oil is probably blowby, make sure you don't overfill your oil and check your case vent tube PCV valve. the case will pressurize and oil will get past the rings.
this helps explain it. https://en.wikipedia.org/wiki/Crankc...ilation_system https://www.motorcyclecruiser.com/un...rcycle-engines Quoted from motorcyclecruiser.com : " If you went through those first few hundred miles without ever holding the throttle open or revving to the power peak—or only did it once or twice—your rings probably never seated".
08-08-2018, 10:30 AM | #7 |
What is this and how do I tighten it, and where can I get a gasket and how do I replace the gasket.
08-08-2018, 11:39 AM | #8 |
see attached
08-09-2018, 07:14 AM | #9 | |
You need a spanner wrench. |
08-09-2018, 07:54 AM | #10 |
The cap is definitely different than the one on my Hawk's engine...it's slotted the same as the cap above the flywheel on the crank case. Spanner wrench is the way to go.
2018 RPS Hawk 250cc Mods so far: 1. Mikuni VM26 Carburetor w/#115 main jet 2. 17T/45T JT sprockets 3. JT 428 X-ring chain 4. Air box mod 5. Hawk Digital Cluster 6. Aftermarket IMS shift lever 7. Performance Aftermarket Exhaust 8. 295mm Nitrogen Gas Monoshock, 20W oil front forks |
