Old 07-13-2018, 12:22 PM   #31
Which Toyota is the intended carb from?
Old 07-13-2018, 10:23 PM   #32
katoranger's Avatar
Early 80s Corolla. New ones can be had pretty reasonable. The starter is not engaging. Probably need to clean it and check connections.
Still waiting on Vermont.
Old 07-23-2018, 02:51 PM   #33
katoranger's Avatar
We can officially move forward. I got a Vermont License plate.
Old 07-24-2018, 11:11 AM   #34
Awesome! I wish I had a work-around like that.
Old 07-24-2018, 09:58 PM   #35
katoranger's Avatar
You don't have to be a Vermont resident. Maybe the will send it to your US address.
Old 07-25-2018, 11:57 AM   #36
It is possible, but that's only part of it. I'd then have to try and explain to the border guard how I registered a vehicle in the US without an American driver's license. I guess the worst case is that I just sell the vehicle in the US and call it a draw.
Old 07-25-2018, 11:16 PM   #37
Darkrider   Darkrider is offline
hell there is a work around like that in sask but this sammi is a year too new to make it work. Anything older then 87 is platable as an antique and does not require inspection.
Past bikes:
'10 Gio X33
'85 Honda VF750F Interceptor
'80 Honda XL185S
'76 Yamaha DT250C dual sport
Baja Wilderness Trail 250
'07 Honda Shadow 750 Areo Trike
'01 Harley Davidson Softail Deuce
Polaris Magnum 425 4x4
Originally Posted by andyj812 View Post
You can't pin this one on me, my wife is still mad at me. I don't need your wife mad at me too. LOL
Disclaimer: The above post by 2LZ is in no way the view of this site, other members or Bruce's llama. It is the opinion of 2LZ and 2LZ alone. ;-)
Old 07-26-2018, 07:16 AM   #38
cheesy   cheesy is offline
cheesy's Avatar
Color me dense here, weld, but why would you need a US drivers license to title and tag a vehicle?
Cheesy
07 Ural Gear Up
79 Honda CX500
77 VeloSolex 4600 V3
73 VeloSolex 3800
Old 07-26-2018, 09:23 AM   #39
katoranger's Avatar
How about someone in the US register it and then "sell" it back to you.
Old 07-26-2018, 11:48 AM   #40
Only if I found a good deal on a vehicle in the US that did not have a title. If there is no title, I can't cross the border with it.
Old 07-26-2018, 11:48 AM   #41
That is totally workable.
Old 08-22-2018, 07:54 AM   #42
katoranger's Avatar
Not much update. I have been working on cleaning up the shop so that I can move it inside for the winter.
Old 10-08-2018, 03:28 PM   #43
katoranger's Avatar
Yesterday we cleaned up the shop. Samurai went inside. Today we installed a used starter, changed oil, new spark plugs, wires, cap and rotor. I hot wired the ignition wires and put a jumper wire to the starter solenoid. Sprayed some carb cleaner in the carb and it fired right up. Next I suppose I need to wire in some switches for ignition and start and also clean the gas tank. It didn't have a gas cap.
Old 10-08-2018, 04:01 PM   #44
Bruces   Bruces is offline
Great job
Old 10-09-2018, 09:33 PM   #45
cheesy's Avatar
That’s a great feeling when you hear that first rumble.
Cheesy
07 Ural Gear Up
79 Honda CX500
73 VeloSolex 3800
