06-19-2018, 02:45 PM | #1 |
VM 26 Issues
Okay been trying to dial in this carb to no avail, so wanted to see if the carb gurus can chime in.
Background airbox mod with K&N filter, Ebay exhaust, valve lash just reset after 100 miles to .03/.04., i am at 600-700ft elevation. Mikuni carb is jetted with 27.5 pilot with 120 main needle on center notch. All seems to run good except when i am in the WOT position, it will pull but then hesitate and pull again like its cutting out? now after i return from a ride when i stop the idle will drop low and engine will die, but will restart no problem. I am no carb guru hell it took me 2 months to dial in my harley, but this one has me baffled as to which way to go?
2017 Hawk 250 1998 Harley Dyna |
06-19-2018, 02:52 PM | #2 | |
As far as dying out when you come to a stop, what is your idle mixture screw set at?n Sounds like it may be also a bit rich on that circuit as well. EDIT: Just to emphasize this point. Make sure to wait until the bike is fully up to temp before making any notes on the change of the tune.
06-19-2018, 02:57 PM | #3 | |
06-19-2018, 04:27 PM | #4 | |
Now still got the idle issue with the 27.5 i have been at 1 1/4 ,1 1/2 and 1 3/4 turns out , now when i finish my ride i can stop and idle is normal for about 30 secs to a minute then it dies??? but it does idle down and stumble right before it does. Edit: i did have a 25 pilot in and recommendation was to increase size due to it stalling when blipping the throttle
2017 Hawk 250 1998 Harley Dyna Last edited by mac1029; 06-19-2018 at 04:30 PM. Reason: correction |
06-19-2018, 06:43 PM | #5 |
Try the idle mixture at 1 turn out. If that doeant help, go back to the 25.
06-19-2018, 07:07 PM | #6 | |
Hope your build is going well and look forward to your videos.
06-20-2018, 09:34 AM | #8 | |
