05-31-2018, 03:14 PM | #1 |
Hawk Digital Cluster
tachometer starts around 3800rpm wont go lower but still goes up less than 400 miles on it any way to take it apart.... i took it off unplugged it took 4 screws out but the damn glue they use i cant get it apart
05-31-2018, 03:18 PM | #2 |
Does it go to zero when you turn off the ignition? Check the inline fuse and + connection. Also check the blue/white wire were you tap in has a good connection. Better to spice and solder it..
05-31-2018, 03:29 PM | #3 |
no stays at around 3800 off and unplugged checked all the wires anyways
05-31-2018, 04:17 PM | #4 |
I guess the best thing to do is contact Matt. This may be something that's happen before and he would be the best to answer your questions.
cluster |
