Old 04-03-2018, 10:53 AM   #1
3banger   3banger is offline
3banger's Avatar
Warp 9 Aluminum Wheel Bling!
Been on my list to do for some time. I actually ordered the Warp 9 rims over a year a when they had a sale. Rims have been sitting on a shelf and I finally made this a winter project. I disassembled the stock wheels and cleaned hubs, spokes and nipples. I more or less followed Warp 9s guide to wheel building here: http://www.warp9racing.com/how-to/ho...orcycle-wheel/. Take your time and lacing up a wheel is pretty strait forward. You will need a truing stand.
I put a dab of grease where each nipple contacted the hub and used a small dab of anti-seize on the threads of each spoke. The stock spokes and nipple are all the right length to work with the the Warp 9 rims. The front the spokes are all the same but the back wheel spokes have different bends to them depending on which side they thread through the hub. These are the wheel sizes I went with:
Rear Wheel (yes it’s spec-ed as a front on the Warp 9 web page) (weight savings 0.75 lbs rotating mass)
3.5” works fine with the tires I’ve picked, they didn’t have any red wheels in the 3” and I went with bling over function...
SM Rims (#89-17363-3) Wheel Type: Front 36 hole, Rim Size: 17 x 3.50,
Rim Color: Red
Front Wheel (yes also spec-ed as a rear on the Warp 9 web page) (weight savings 1.5 lbs rotating mass)
Same width as CSC 19” upgrade wheel.
MX/Enduro Rims (#89-19363) Bike Type: MX/Enduro,
Rim Grade: Standard 7000,
Wheel Type: Rear 36 hole,
Rim Size: 19 x 2.15, Rim Color: Red
File Type: jpg 9FAB8B8B-3708-4467-8D72-9CA8B1C4E217.jpg (20.4 KB, 402 views)
File Type: jpg 91E18A87-B828-41E6-B906-8464C294EAAF.jpg (20.2 KB, 402 views)
File Type: jpg AEC7D13B-D240-455F-A838-0722EC0CF29E.jpg (19.8 KB, 407 views)
Old 04-03-2018, 10:57 AM   #2
3banger's Avatar
And here are some of the rear wheel build photos; build photos are always best presented upside down...stupid iPhone orientation EXIF data!
File Type: jpg 867B33B8-DFB2-41F0-9AB1-06FB2026F906.jpg (19.7 KB, 401 views)
File Type: jpg 4D19B6F6-09DC-4107-8EB2-A05DAA102B80.jpg (20.3 KB, 391 views)
File Type: jpg E2E37BC6-A9B5-485B-8B3B-4E70DFBCA391.jpg (20.3 KB, 402 views)
Old 04-03-2018, 11:05 AM   #3
joker29888   joker29888 is offline
Rim Color: Red
Front Wheel (weight savings 1.5 lbs rotating mass)
i think you have write front and rear rim upsidedown rear 3.5x17 and front 2.15x19
Old 04-03-2018, 11:07 AM   #4
3banger's Avatar
Front wheel build photos
File Type: jpg 3494CD33-4C06-4846-9B67-3499FFD3C2AD.jpg (19.9 KB, 389 views)
File Type: jpg 9364B92D-420A-40A3-B7E7-BEAA5BE4257A.jpg (16.9 KB, 399 views)
File Type: jpg A2B61703-F76C-405E-9C3D-7635CD20676C.jpg (16.9 KB, 404 views)
Old 04-03-2018, 11:13 AM   #5
Your truing stand is much fancier than mine. What brand is it?
Old 04-03-2018, 11:30 AM   #6
3banger's Avatar
Home built special; happens when you turn an engineer loose with a welder...so brand NoMaas! Since I’m David Maas.
Old 04-04-2018, 11:06 AM   #7
May we see some detailed pics of it? I'd like to see how I could improve on my stand.
Old 04-04-2018, 11:21 AM   #8
sjeff35   sjeff35 is offline
Looks sharp. Do they have the fast Orange color???
Old 04-04-2018, 12:42 PM   #9
3banger's Avatar
Because KTM they have lots of Orange!
File Type: jpg AE4D3D81-9F96-4022-8790-9CFEC8345AFE.jpg (8.5 KB, 367 views)
Old 04-04-2018, 12:47 PM   #10
3banger's Avatar
Joker29888
So you are correct the rim I used for the rear is a front 3.5x17” in the Super Moto section on the Warp 9 site. And the rim I used for the front is a rear 2.15x19” in the MX section of the Warp 9 site.
Old 04-04-2018, 01:01 PM   #11
3banger's Avatar
Since it was a request here are more truing stand detail photos. Width was dictated by my Marc Parnes wheel balancer http://www.marcparnes.com. The indicator arms are part of large hardware store (Ace) turn buckles and the knobs are from the Ace bits and pieces drawers. Same with the rubber leveling feet. Metal is what ever I could scrounge. Height to accommodate a 29” Mt Bike wheel though I’ve never used it for bike wheels just yet. Mostly just made it up as I went.
Again I don’t know how to solve the orientation problem, if I rotate image to account for it before posting it doesn’t make a difference? Sorry for that.
File Type: jpg A55C93E8-73DF-4101-B611-C4E9D1FAB06C.jpg (19.8 KB, 349 views)
File Type: jpg 1677D1D7-20EF-4E2E-926C-F0E43DC2F357.jpg (13.9 KB, 347 views)
File Type: jpg 62C88319-FAA1-486D-AC60-2419584D3882.jpg (16.1 KB, 347 views)
Old 04-04-2018, 01:10 PM   #12
Nice stand
Tip on pictures, Take the pictures in landscape mode and they will display correct when posting.
Old 04-06-2018, 06:49 PM   #13
and what size of the rear tyre with that rim?
Old 04-07-2018, 09:58 AM   #14
3banger's Avatar
I’m running a Heidenau K60 Scout Rear Tire Size:130/8017 65T TL. It’s rated for a 2.5 to 3.5” rim.
Old 10-16-2018, 09:52 PM   #15
sqwert   sqwert is offline
Warp 9 2.50-19 front (rear MX SKU: 89-19362-2) $135.00
Warp 9 3.50-17 rear (front SM SKU: 89-17362-3) $179.00
csc 36 front spokes @ $1.75 each = $63.00
csc 18 in and 18 out rear spokes @$1.95 each = $70.20
csc spoke nipples front 36 @ 0.75 each = $27.00
csc spoke nipples rear 36 @$0.25 each = $9.00
csc front hub assembly $79.95
csc rear hub assembly $99.95
$660.10 just for parts for two wheels to maximize the performance of street tires stock sizes? Sheesh, hope I badly screwed the math.
