01-08-2007, 11:09 AM | #16 |
Yeah, that's what I figured. Mine is definately an OHC then. So any word on how we adjust the tensioner and how often it needs it??? I wonder if Roketa has a tech line or someone with mechanical knowledge at their main facility in CA????
01-08-2007, 11:17 AM | #17 |
I have speculated that I would have to take the starter off and turn the screw to the left until I "feel" resistance, but I don't know for sure.
Jason
2008 Jonway MC-70-150 2007 Roketa DB-07B (RSM-200E) 2006 Roketa DB-07A (RSX-200E) 1995 Kawasaki Concours (ZG1000) |
01-08-2007, 07:30 PM | #18 |
The proper way to adjust the tensioner if you ever opened the cover you will see 2 hex head bolts, do not tamper with the inner bolt. Its a bolt within a bolt. Remember do not touch the inner bolt. Next get a manual for a Honda 200xr it will tell you the full details on setting the correct tension. Ive done it a time or two once upon a time in history past, its not difficult at all. The adjustment port is located behind the starter. I know this isnt much help but its a start to knowing where began.
01-09-2007, 07:43 AM | #19 |
The xr 200 doesn't adjust the same as these bikes do. I looked it up yesterday. They have a totally different chain tensioner and the XR motor doesn't even have a bolt on the back side of the motor where ours is. We need a Roketa tech to answer this!
01-30-2007, 11:01 PM | #20 |
forgive me for being stupid
but does the lifan have an ohc engine?
01-31-2007, 01:08 AM | #21 |
yes they have an ohc motor, i've seen it for sale by itself, but havent seen it in one of the gy frames... so who knows..
