03-10-2018, 01:25 PM | #1 |
Sukida SK125-2 help
Follow on from my last post finally managed to get time to finish the bike and everything works but I Still cant get the damn thing to fire up. I did have the carb rebuilt before I started all the work on the bike but I don't think it has been set up correctly.
does anyone know where the best place to start is with the idle screw and the pilot jet screw. the other thing I will be trying tomorrow is a fresh tank of petrol just to see if it is the petrol that is the issue. |
03-10-2018, 07:19 PM | #2 |
Going to get my compression tester tomorrow and check the compression on the cylinder does anyone know what it should read as I have ordered a Haynes manual but it hasn't arrived yet.
03-11-2018, 09:13 AM | #3 |
Honda https://josemaco.files.wordpress.com...h-62ktjam5.pdf said normal 12.? & don't list the wear limit
Kymco had wear limit 1st hand info from mechanic http://www.motorfans.com.cn/forum.ph...d=75082&page=3 51# Anyway http://www.dansmc.com/compression_test.htm is very useful http://www.onlineconversion.com/pressure.htm for non-SI unit tool
