2017 Bashan Enforcer 250 and Bashan Storm 250 assembled.
So I assembled both bikes which were easier then I thought. They ride completely different and I noticed a difference between the counter vs non counterbalanced engine. I'm currently changing the oil on both. The carb issue was a pain at first but then I think it set in good when adjusted. The battery went dead on the enforcer and when I tried to remote start it it kept trying to start before I disconnected it. I charged battery back up and no problems. Do I need to change carb on these 2017 models or are they good.
Nice! I've always liked the Storm and I'd own one if they were legal in CA.
Carb should be fine on the Bashans. Still might need a little fine tuning, but the jets should both be standard Keihin units. The Hawk carb really isn't a bad one, just has a goofy pilot jet that can't be changed, and the tamper proof bowl screws make it annoying to change the main jet at first.
Now if you take the Enforcer front fender, headlight, and wheels and put them on the Storm... or swap the front triples and forks on to the Enforcer. You would have the bike that everybody actually wants to buy lol.
NICE BIKES!! This waiting game is giving me withdrawls! COME ON PEACESPORTS!!
My Stable- 2022 Lifan KPX250 , 2023 Royal Enfield Himalayan, 1992 Honda GL1500 Goldwing, SSR 70 Auto, Kymco Mongoose 90, Honda Four Trax 300 |
Since you have both...Is it possible for you to get them both in the same picture in a profile? I am still mulling over which one would be better. I ask because I am curious what the seat height difference really is.
#8 | |
Minus the handguards.
2016 Brozz |
#9 | |
#10 | |
Here are some of the other pictures i will try to do more again later. I took the Storm out on the road with my kid 125lbs on the
back and it performed great. I did notice that it was having trouble starting when not in neutral this must be a safety feature now? |
Does anyone know if the digital hawk cluster would work for this and what about a fuel gauge. I tried switching the light and fender over but the brackets for the lights don't align. It did look good tho.
I'm thinking of getting this helmet as a star wars theme lol.
#14 | |
Sorry to hijack, china007...you have gotten the proverbial best of both worlds with your Bashans--one to cruise the streets, and the other to explore dirt roads. Supposedly the Brozz is arriving in the next few weeks/months (According to the current importer), so I wonder if you have one of those on your mind to add to your collection. You know you want one... ![]()
#15 | |
There are only 3 things to really verify. The pin layout of the plug for the gear indicator. The pattern on the cluster mounting bracket, and the speedo drive on the front wheel. I would almost bet they are the same, or so close it can easily be made to work. As far as it working on the storm, if you can confirm it will work on the enforcer, then you can compare the Enforcer hardware to the Storm stuff and see if they can interchange between your two bikes. Wiring and cluster wise, I am sure they are pretty close, but the speedo drive may be the issue.
