Old 03-02-2018, 10:10 PM   #1
Waldo38   Waldo38 is offline
Head Scratching RX3 lowering link.
Has anyone installed the lowering link on the RX3 and have issues with kickstand being to tall? Bike doesn't lean far enough.
Old 03-03-2018, 04:52 AM   #2
TheycallmeD   TheycallmeD is offline
TheycallmeD's Avatar
Only when I put the CSC kickstand foot on it. Had to remove it was scared the bike was going to fall over
"D"
2007 Suzuki Burgman 400
2016 Zongshen CSC Cyclone RX3
2008 Arctic Cat 700 trv
Old 03-03-2018, 12:29 PM   #3
GSC   GSC is offline
yes my experience was different. CSC lowering link w the CSC expanded foot on the kickstand. also CSC 19" front wheel and CSC Kenda Big Block tires front and rear.
off road, uneven terrain, found it much, much better for me to mount and dismount. surface is mostly soft and always uneven of course.
road terrain, still advantageous to me. i step onto peg and swing my leg over. then heft her upright. i like it more straight upright for the hefting part. i have very short legs though. its all relative i guess.
Old 03-03-2018, 04:05 PM   #4
jbfla   jbfla is offline
I put the lowering link on my RX3, which lowered the bike one inch.
But like GSC, I put on the 19" front wheel, and a different rear tire, which raised it back up 1 inch......
No problem with the kick stand.
jb
2014 XT 250........
Old 03-04-2018, 10:39 AM   #5
GSC   GSC is offline
its true; lower link, higher wheel, taller tires, and foot peg enlarger. back to square one ?
Old 03-04-2018, 06:09 PM   #6
Dualsport Chic   Dualsport Chic is offline
Dualsport Chic's Avatar
However, the larger front tire provides you many more tire options so it is a benefit if you don't mind losing some travel with the lowering link.
Carpe Diem
IBA#65836
2005 BMW F650gs
2008 Yamaha XT250
2013 Yamaha XT250
2009 Suzuki Gladius
Old 03-05-2018, 12:11 PM   #7
Put the lowering link on Mrs 2LZ RX3. It's basically stock with the stock front wheel.
No really issues. On flat ground, it's fine, though she does have to be a little more attentive to where she parks.
Old 04-17-2018, 03:23 PM   #8
nocalbruin   nocalbruin is offline
My 2014 had the lowering link installed at the factory. Yes Waldo38, the lean angle is definitely not enough to feel comfortable. I removed the sidestand and took it to a local metal shop. They cut about an inch out of the middle and re-welded the the top and foot back together. Cost me $25.
To remove the sidestand spring, use the pennies in the spring trick. You can find a video on YouTube.
