Rear break hanging up
Have any of you found that the rear brake caliper will hang up from time to time? Dad's does and we have to stop and crack the bleeder valve to release the pressure. We've already changed the brake fluid once. The only other thing left is to completely disassemble each component to see if there is trash in the line somewhere. Before we do this, does anyone else have a suggestion as to what would be causing this?
Jason
2008 Jonway MC-70-150 2007 Roketa DB-07B (RSM-200E) 2006 Roketa DB-07A (RSX-200E) 1995 Kawasaki Concours (ZG1000) |
#2 | |
Re: Rear break hanging up
Ok, that sounds like that could be it. I know the resevoir is tilted the way it's mounted, so where should the top of the level be so that this doesn't happen. I know Dad has his at the top and mine is near the top. The rubber boot is also something that is in question. Should it be all the way out and into the brake fluid or should it be all the way together at the top? Could this be part of the problem?
Jason
Good question mine has done the samething twice I will check the level should I change the fluid as well. Any pointers on the best way to do that would be appreciated thanks.
BTW Jason Im legal now. I have your number maybe we can go for a ride some weekend soon. the 3 of us it'll be the only china bike gang in Cola. LOL ![]() |
Maybe obvious, but is there a bit of free play in the pushrod? Mine was a little tight.
Jonathan |
[quote=BTW Jason Im legal now. I have your number maybe we can go for a ride some weekend soon. the 3 of us it'll be the only china bike gang in Cola. LOL
![]() Great news!! Yeah, that would be great! If the weather holds for the weekend, maybe this weekend. Jason
#7 | |
Thanks!! Dad's had more of a problem than I have. He'll be glad to fix this problem. Now, if by chance the fluid is as you say with a 1/2 in of space, what next? I know I've cracked the valve on his a couple of times during a ride and let out fluid but didn't really help but for another 10-15 miles then we would have to stop again. Should I have also taken the resevoir cap off and put it back on? Another thing, I think the pad to disk tolerance is very tight when the pads are new. Mine are well worn now along with my rear tire and his aren't since he doesn't ride his very aggressively.
Jason
That's a good point Fatboy. I found the same condition existed on my brand new TSM, but with the reservoir open and the bleed valve open I was able to open the caliper enough to slide it over the rotor, but it was tight.
2009 XR650L Big Red Pig Tusk bar risers 2007 X-Moto(Jetmoto) GY250 --mods--- 15/40 sprockets UNI Pod Filter 2007 Shineray TMS 200XYi--Betsy ![]() Betsy Mods:______________________ Acerbis DHH headlight FMF Powercore pipe Uni Pod Filter |
#10 | |
Yeah that pretty much describes it. He'll be riding along fine at like 50-60 and then start noticing the engine struggling to pull. I will let you know.
Today I took the cap off the brake resovoir sure enough the diaphram was down inside it and was completely extended. I think that may have been my problem. L had never taken the cap off I could just see fluid through the plastic and that was good. Ill ride a while and report back.
fingers crossed Ray |
#13 |
mine has done the same thing twice so far. ui have ordered a complete new new rear brake setup. we'll see if it helps...... i think it;s just the adjustment of the pedal though.
Roketa DB-07a HID Headlight |
#14 |
Mine got tight too. Caliper & rotor got purty hot... I just grabbed my 8mm wrench from my toolkit, ( everyone rides with tools, right?) popped the pressure on the caliper and it has been OK since. I am going to replace all the fluid (front & Back) with good DOT 4 fluid soon so it should be OK.
The destination is merely a by-product of the journey. '06 KLR650 '06 XT225 '92 XT225 Serow ( MBD.... Multiple Bike Disease...) |
#15 |
I had a lot of problems with my brakes seizing and I found that my brake line was not lined up correctly which was stopping the fluid flowing back from the brake.
