Old 02-17-2018, 07:22 PM   #1
seadog   seadog is offline
Sukida SK125-2 Electrical Help
Evening Everyone First time here.
I am hope that one of you great ladies and gents will be able to help I found a cheap Bike on ebay as a winter project to keep me busy while I try to give up the smokes. My problem now is that while working on it someone has done a bodge job on the wiring and replaced some of it with extension lead wire so my next job will be rewiring it but I cant find a wiring diagram for love nor money with out having to pay stupid money.
what I am hoping is that one of you will be able to help and share one with me.
thank you in advance.
Seadog
Old 02-17-2018, 09:20 PM   #2
humanbeing's Avatar
As i said b4 Divide into groups http://www.chinariders.net/showthrea...783#post229783 made the job less hassle. Read enough examples from http://do.ejdz.cn:8087/%E6%91%A9%E6%...B%BE%E7%BA%B8/
[upper E-start | Charge & lighting / Lower: Ign | signal] trains the brain slove wiring ? in seconds.
Anyway https://josemaco.files.wordpress.com...h-62ktjam5.pdf is useful for maintenance works.
Old 02-18-2018, 01:22 PM   #3
Welcome!
Are you in the UK? I'd love to see a pic of your new bike. Good luck on ditching the smokes; hardest thing I've ever done.
Old 02-20-2018, 08:18 AM   #4
[QUOTE=Weldangrind;273738]Welcome!
Are you in the UK?
Yeah I am in the UK.
I will fish some old photos and I will take some of it in its current state.
Thanks the bike is helping by keeping me busy when I'm at home.
Old 02-20-2018, 08:42 AM   #5
this is the only photo I have of the bike when I fist got it.
Old 02-20-2018, 11:09 AM   #6
That's an old CG125 clone. You can now expand your search criteria for wiring diagrams. The reality is that anyone on this forum with a CG-based engine will have a similar harness, except for minor differences like AC vs. DC CDI ignition.
If it interests you, you could pop a CG250 motor in that frame, and no one would be the wiser.
Old 02-20-2018, 05:04 PM   #7
That is the plan long term but I want to finish the aesthetic work so it looks like a 60s café racer, get it running and back on the road first before looking for a 250 engine.
Old 02-20-2018, 10:19 PM   #8
humanbeing's Avatar
That's an old CG125 clone...
Not 100% as good old skinny http://bbs.fblife.com/forum.php?mod=...uthorid=153464 CG. Those alloy wheels resembles another Honda model that using more beefy shoes https://item.taobao.com/item.htm?id=39488278838
Kickstand s/w in these bike ALWAYS a joke, bypass it ASAP.
Originally Posted by seadog View Post
... before looking for a 250 engine.
Another economical mod = Fit a 62mm CG150 barrel kit & made it's c/r to 10.*:1 http://www.motorfans.com.cn/forum.ph...d=75082&page=1
Old 02-21-2018, 11:02 AM   #9
That's the perfect bike to start with. Like Humanbeing says, the alloy wheels aren't like the old CG, but those are easily changed. For inspiration, use Google Chrome, go to www.taobao.com and type in café racer; allow it to translate automatically. You'll be amazed by the stuff that is designed for a CG125.
Old 02-22-2018, 01:10 AM   #10
humanbeing's Avatar
...go to www.taobao.com and type in café racer...
Keywords: "復古" "cg" "改" in taobao
http://www.dotheton.com/forum/index.php?topic=19767.0 is a good example
Old 02-24-2018, 07:03 PM   #11
Finally had chance to get out side and take some photos of the bike in its current condition.
Old 02-24-2018, 07:22 PM   #12
Had a productive day managed to pull the old loom off the bike.
Fitted a new fused bus box and got that all wired in to the switches
Wired the switches to a distribution bar to make fault finding easier when the bike is completed (see attached photo haven't taken one of it on the bike yet as I couldn't feel my fingers)
Just leaves the reg/rec stator and the CDI unit but need some help with the CDI unit anyone know where the wires go on the CDI unit as this is where the extension lead wires were.
Will add photos of the fuse box and distribution box next time I'm working on the bike.
Old 02-24-2018, 10:37 PM   #13
humanbeing's Avatar
https://www.microsofttranslator.com/....asp%3Fpid%3D5
Old 02-24-2018, 11:54 PM   #14
I was sent these on another bike forum and the poster said that he believes these to be the correct positions but colours could be different. Having never wired up a CDI unit before I just want to make sure that they look correct.
Old 02-25-2018, 01:41 AM   #15
humanbeing's Avatar
Typical chinese CDi should be as the aboves. Bu/Y often found in REAL Honda, Bu/W in copycats
https://www.microsofttranslator.com/....asp%3Fid%3D16 proven ur guess into facts b4 plug anything in
Same shape ≠ Same pinout http://www.microsofttranslator.com/b...uthorid%3D2790 by bike electronic engineer
Grabbed via https://en.wikipedia.org/wiki/CNKI in library
