Old 01-18-2018, 06:36 PM   #16
da4design   da4design is offline
da4design's Avatar
nice looking bike, making me think about getting one!
Old 01-18-2018, 06:39 PM   #17
letsride   letsride is offline
You need to warm it up and adjust the idle, using the idle adjustment screw on the side of the carb. Now I can't remember which position of the choke lever is ON! Someone will be along shortly to answer. I think DOWN is ON! if I remember right.
My Stable- 2022 Lifan KPX250 , 2023 Royal Enfield Himalayan, 1992 Honda GL1500 Goldwing, SSR 70 Auto, Kymco Mongoose 90, Honda Four Trax 300
Old 01-18-2018, 08:48 PM   #18
MacGregor   MacGregor is offline
I had to turn the screw in about 2 1/2 turns for it to idle with the choke lever up, however the lever down causes it too idle way high. I took it for a quick ride and it sputters on acceleration (it didn't before). I don't want to do any more until I get the oil changed, so I'll do that shortly and save the rest for tomorrow.
Old 01-18-2018, 09:10 PM   #19
Great Progress! Can't wait to see some pitchers! What color is the thing? I'm trying to find the original "Enforcer" Thread of (I think) the first to guys to purchase and document them here.
You really should get your eyes checked.
Old 01-18-2018, 09:11 PM   #20
Bike looks great.
Old 01-18-2018, 09:13 PM   #21
Chock lever all the way up is on and all they way down is off. Adjust the idle with the chock off.
Old 01-19-2018, 11:04 AM   #22
Nice looking bike! Thanks for the pics.
The spring for the kickstand is a bit tricky. I used a screwdriver, which worked well.
As a tip for the next China Rider to install a kickstand spring, insert several washers or coins between the coils of the spring. That will expand it to a length that makes it easy to install without producing any blood.
Old 01-19-2018, 12:48 PM   #23
I can second the coin trick, having used it before. Another option is a good old fashioned drum brake spring tool. It is literally designed for this exact type of work - to install small stiff springs on spring studs with rounded ends. Makes it a breeze.
Old 01-19-2018, 04:25 PM   #24
The assembly wasn't bad at all. I would probably recommend buying from a different retailer than where I got mine, but overall I'm very happy with it.
Old 01-19-2018, 04:27 PM   #25
Thanks, I think that may have worked. I let it warm up first then adjusted it. Just went around the block a few times. No sputtering at all. It's got a bit of grunt for a little 250.
Old 01-19-2018, 04:30 PM   #26
Just a note - the handlebars and grips are aftermarket. I got the Tusk Chub bars with the YZ bend. For reference, these were pretty close to the bend of the stock bars (the Chubs are about 1" longer on each end, with slightly less pullback. Rise is about the same.)
Old 01-19-2018, 06:16 PM   #27
It only gets better as it breaks in. A free flowing exhaust and carb tuning it gets even better. These are fun bikes to play around with and not cost an arm and a leg. Lol
Old 01-19-2018, 06:49 PM   #28
Or a quick and easy head porting job.
Old 01-19-2018, 07:02 PM   #29
I'm planning on doing the eBay exhaust and rejet. I'll probably leave the gearing stock, but replace the chain.
250, bashan, chinese, enduro, enforcer
