Old 12-18-2017, 02:44 PM   #106
More aggressive like you did. I have some abrasive buffing wheels coming in tomorrow so I can polish it out. https://www.amazon.com/gp/product/B075PVWJXX
Old 12-18-2017, 03:04 PM   #107
I bought those exact ones lol. They work good for polishing up the exhaust side, which I just finished doing.
Old 12-18-2017, 03:20 PM   #108
For the price I couldn't pass them up.
Old 12-21-2017, 08:47 AM   #109
Picture updates????
Old 12-21-2017, 10:12 AM   #110
I get home tomorrow. I will try lol
Old 12-23-2017, 02:25 AM   #111
Here Jerry. I tried to show it, but Cameras don't do a good job of showing the finish. It's a lot more shiny than it appears lol. This is my finished product after a bit more work. I trenched out the sides of the valve guides and blended them in more with the bowl. No more ridges!
Old 12-23-2017, 03:49 AM   #112
Surely you will feel a little crisp-ness in the throttle now. That looks like a nice air molecule slide to me
Old 12-23-2017, 04:46 AM   #113
Oh, I think it will be a bit more than crispness. Full on burned and crunchy. I will let these similar angle before and after shots speak for themselves.
I tried to get the angles exactly the same, but not quite perfect. Close enough to make a point though. I still have a little more I want to do on the intake side, but for the most part I am done.
Old 12-23-2017, 05:01 AM   #114
pete   pete is offline
pete's Avatar
the shape looks good..
keep at the finish... you will get there..it takes time..
09 XT660R ...
06 TTR250 ...
80 Montesa H6 125 Enduro...
Current resto projects..
81 Honda CT110...
80 Kawasaki KL250A1...
http://www.remotemoto.com/
E-mail... xtpete1@gmail.com
Old 12-23-2017, 05:17 AM   #115
I am not too worried about the finish. It's smooth to the touch, but the camera shows a lot of the imperfections you can't see with your own eyes, mostly small scratches. It's the shape of the port that matters the most. Obviously, I will still work at it a little bit, but it's 99% there at this point.
Old 12-23-2017, 10:56 AM   #116
Looking good .
Old 12-23-2017, 11:56 AM   #117
ben2go   ben2go is offline
The ports really opened up nicely. A regrind cam would help but with a single lobe, how much would it really help. Would it be possible to play around with offsetting the cam sprocket? I'm not sure if it uses a key, a pin, or some other means of keeping them together and in time.
Old 12-23-2017, 01:30 PM   #118
I don't doubt that the right cam profile would help. Sharing a cam lobe doesn't mean you can't get more out of a new cam profile. CCW surely managed to get a lot more out of their engine with one. (23whp from a counterbalanced cg250 is nothing to snort at).
For me, it's more a matter of useable power. I want to try and keep a flatter power curve. That is why my intake porting is a little less aggressive than the exhaust side. Even if that means I sacrifice a little peak hp, I am okay with that. These engines already have a larger than necessary intake port, so simply focusing on smoothing transitions and reducing the pinch point at the valve guide is more than enough.
The exhaust side is the greatest restriction in these heads, bar none. Being able to evacuate the exhaust from the cylinder as quickly and efficiently as possible will make more room for fresh air and fuel, which will increase the efficiency of the intake side. The roof area on an exhaust port is the best place to perform porting for making more power, and also where these heads need the most work. You will notice that the majority of my porting work focused on opening up that exact area.
Old 12-24-2017, 12:45 AM   #119
Meg...can you get an app that will measure g force or some kind of hp simulation so you can take road measurements? Saying this since it seems you indicated previously that the dino fell thru. I think this would be a good way to at least quantify what you have done. No, it would not be accurate/ perfect and all that but just like a inaccurate bathroom scale, as long as you use the same one you know what you have gained or lost.
Old 12-24-2017, 01:47 AM   #120
My plan is to try and get this bike into the dyno sometime in Feb. or March, and then install the head and tune the carbs. again. I can do without a before/after dyno of basic bolt ons, because realistically we all have a rough idea of what a bolt on CG250 can produce in terms of power. I refuse to let the head work go unquantified, because that is a bigger unknown.
I think the only thing I will leave out is a dyno with the VM30 carb. The VM26 will be far easier to adjust the jetting for and get back on the road. Plus, I think it would be more realistic in representing what most Hawk/Bashan/TT owners would want to do. The VM30 will require a lot of tuning from scratch.
