Hawk 250 Custom-ish
Got this Hawk in early April with 36 miles on the clock
Not a fan of the styling nor the other mechanical shortcomings. So I’ve made a number of mods. Sprockets and Upgraded rear sprocket fastening (tapped the bushings in hub and bolted directly through sprocket to bushes) Shinzo 244 4.60 rear, 3.00 front 225 ml of 15 weight fork oil Hand built fork brace (modified 4x4 fence post anchor spike) VM26 with 115 main jet and cone filter, removed air box Custom aluminum battery box Removed catalytic conveyer and wrapped pipe NGK Irisim plug Crank case breather filter cone Remove and replace most body bolts Remove all plastic and de-tab frame Remove all paint and apply non-painted finishing to many surfaces Drop muffler mount 1.75” to smooth lines Seat foam re-shaped, added to and covered in marine grade vinyl Handbult rear fender (0.080 aluminum) Replaced all lighting (LED headlight and driving light, total draw 2.5amps) instrument cluster with tach Modified wiring loom and relocate to under seat Replaced hand controls, grips and mirrors Relocated rear brake reservoir (plan to move up between rear door peg mounts, build and install a guard) Ram mount on bars Remove header heat shield and repurpose as chain guard Trim front sprocket cover I’ll update the photos later from the computer. This here phone won’t keep my images upright. Last edited by richinar; 12-04-2017 at 02:42 PM. |
Looking forward t seeing more pictures.
Heck yeah. You did what I have considered doing with mine for a little while now. I Always thought about removing the plastic and making it look more like an older 60's and 70's style dirt bike. I would still consider some kind of front fender though, such as an old SL350 front fender. http://articles.superhunky.com/image...126/SL3502.jpg
Nice job with the battery box.
Plan on removing the tabs for the tank plastic mounts and smoothing the tank out?
Wow!
Now that’s what you call “All Out Modding”! Plus, you can sell all of your plastic parts!
Thanks for the kudos
Hard to put things aside and move on Probably going to go with a tracker-inspired back end and seat. Put the MSR shifter on but didn’t like the clamp’s clearance so have chopped it off, trimmed its length a little and welded onto the stock clamp. The fender slides into the frame between the sheet metal bracketry and tubes to fit extremely snug. I’ll probably rebuild the battery box with a slope towards the rear to house the electronics in a foam-lining and deter the vibration which is likely imparted by having the ECM and flasher zipped onto the frame. I took out the sheet steel cross-brace under the seat and put in a tube. |
#14 |
That’s beyond my patience and skill. I kinda like the ability to have highly polished and less polished it affords, with the resulting accumulation of polishing compound and metal dust in the deep cracks being a desirable outcome.
———— ‘16 Hawk 250 changed up a bit ‘85 Virago 1000 changed a bit more |
#15 |
Excellent!
What we need though is a photo taken from the side of your bike which shows the whole bike, front to back. I think an image like that would really show off the 1960's dirtbike character, and might start a stampede of copycats - me at the forefront... |
