Old 08-10-2017, 11:52 AM   #1
Spiderman   Spiderman is offline
Lifan 200cc issue
So I recently got a lifan 200cc motor. Ran for about 2 miles and stopped. Got it home, opened valve cover, found the exhaust side pushrod sitting next to the rocker arm wedged in. I pulled the rod out and found about a 1/32"-1/16" bend in it. Replaced both rods and set correct clearance to about 0.05mm. But now it won't fire up, is there anything I can do? Something I did wrong or something else possibly damaged?
Old 08-10-2017, 12:19 PM   #2
Mudflap   Mudflap is offline
I doubt if the push rod popping out of the socket would damage anything, but the big question is why did it pop out in the first place? Any chance you over-revved the engine to the point of valve float and bent a valve? I'd do a compression test.
Old 08-10-2017, 12:46 PM   #3
Oh forgot to mention that. When I reinstalled the pushrods I found that the clearance for the bent side was way out of spec. It had a large gap. So Im thinking it was just too loose and when I actually started riding it it popped out. But I'm gonna do a compression test next. I do feel a considerable amount of air coming out when I remove the spark plug. But I will check the actual psi levels.
Old 08-13-2017, 05:32 PM   #4
humanbeing's Avatar
There's 2 type:
Check it 1st b4 order anything
大东 http://www.cqdadongqimen.com/ a big player in OEM
正洲 (100% owned by Taiwanese, some of their product found in chinese made Honda/ Suzuki ) https://item.taobao.com/item.htm?id=548474724568 also OKish
Stock water-cooled LF200 push rods are made of Al alloy https://item.taobao.com/item.htm?id=15971280760
Old 08-13-2017, 10:14 PM   #5
wheelbender6's Avatar
What bike did you install that Lifan 200 in?
Old 08-14-2017, 07:54 AM   #6
Originally Posted by humanbeing View Post
There's 2 type:
That's a huge help. Thanks for that.
Old 08-14-2017, 07:55 AM   #7
1971 honda cl100.
Old 08-14-2017, 12:51 PM   #8
Inquiring minds want to know!
Old 08-14-2017, 11:45 PM   #9
Doubling the displacement makes me giggle.
Old 08-15-2017, 08:04 AM   #10
I would be giggling with you, if the flipping motor hadnt killed itself.
Old 08-28-2017, 10:51 AM   #11
Any word on the compression test?
Old 09-09-2017, 05:34 PM   #12
So I got it running pretty well for like a week. Now it wants to lurch and studder and bog down. I've taken the carb apart and cleaned it. I've replaced the fuel. Tried various setting on the carb. The spark plug isnt white or black. It's a nice chocolate color. So I don't know. Anyone have any suggestions?
Old 09-10-2017, 12:21 PM   #13
There is a running Honda SL 125 for sale on my local Craigslist for cheap. I'm tempted to buy it and install the 200cc Lifan. I rode an xl 125 for years in my younger days.
Old 09-16-2017, 12:00 PM   #14
Buy a new CDI for testing purposes; it's always good to have a spare. Aside from that, I'd install a 30mm Mikuni, which is easily found on eBay for less than $40 shipped. They're easy to tune and jets are widely available.
