Old 10-07-2016, 05:11 PM   #1
Misha   Misha is offline
Engine vibration
Hi guys, my name is Misha, I'm new here, so here's the first question:
I recently bought a Peda 250ST 230cc. It has huge vibrations from the engine, like most Chinese ATV's. How can I reduce them, I thought about some kind of rubber in the engine mounts?? What rubber should I use and how should it look like?
Thank you in advance and nice to meet you, hope you have an awesome day!
Old 11-04-2016, 09:46 AM   #2
Tred   Tred is offline
hi micha. new tew. but i had same with my Zongsheng. I'm hopeng can smooth it out with some timing adjustment. not a mechanic but just a hunch. going to check the valve gaps and reset the timing line up. letcha know what comes of my idea.
Old 11-04-2016, 10:36 AM   #3
Merlin   Merlin is offline
Exclamation
Dont use rubber in the engine mounts it dosent work youll just brake your mounts. The vibrations from the engine need to spread out somewhere. Make sure all the motor mounts are tight a loose motor mount will cause vibration. Check your valves for adjustment. Tuning is your best bet.
Old 11-04-2016, 10:54 AM   #4
If it's a CG motor, they're notoriously buzzy when new and that will get better with hours. Make sure your motor mounts are torqued properly. "Evenly" is far more important that "damn tight". They only torque to 18-22 ft lbs, respectively.
Old 12-17-2016, 09:10 AM   #5
Any luck Tred?
Old 12-17-2016, 09:12 AM   #6
Thanks a lot, i will check the mounts, I have a feeling they are too tight, there were 2 or 3 mounts I think?
Old 12-17-2016, 09:56 AM   #7
It depends. Just follow the motor around starting from the top. You'll probably see two different bolt sizes (thicknesses), as to the 18-22 ft lbs stated earlier. The fatter bolts set to 22 and the skinnier bolts set to 18.
Let us know what you find!
Old 12-17-2016, 11:18 AM   #8
vibration
I agree that the rubber mounts would not work..... has anyone ever tried a small sheet of plastic... ??? like the puckboard stuff or what they use those snow sliders out of..??? would be interested in that..
ABIBABA ATV ETC
Old 12-17-2016, 03:53 PM   #9
Yeah there were smaller bolts on the front mount and they were a little loose, sadly i don't have a torque wrench with a meter so I don't really know how much I should tighten.
Old 12-17-2016, 06:35 PM   #10
22 lbs is "a tad more than snug". 18 is "snug". No need to bear down on them. They're only thin shanked bolts.
Old 09-15-2017, 09:48 PM   #11
clark   clark is offline
clark's Avatar
Magician 250 vibration
Any luck with reducing the vibration?
I have a Magician 250 (229) enduro, and above 30mph have quite a bit of vibration (from the engine?) Cruising at 50mph, I use cowhide gloves to help reduce some vibration to the hands. After about 15 minutes my fanny is going numb from vibration.
I have not tried adjusting the valves.
Anyone else experiencing this in either Magician or Hawk?
(I kinda figure maybe it's just the natural shaking force / vibration of a small single jug engine? Kinda disappointed if I cannot reduce this vibration.)
Magician 250 (9/2016 engine label)
Kawasaki 650 KLR
Honda 1300 VTX
Qlink XF200
Old 03-15-2022, 03:56 PM   #12
mark77   mark77 is offline
where are the motor mounts, all i see is 2 long bolts in the back under the seat .is that all that holds the engine on.Its for a kids Tao 125
Old 03-15-2022, 07:45 PM   #13
franque   franque is offline
If you've got the same engine, no. There should be two on the back, two on the front, and one up top.
Old 03-16-2022, 05:29 PM   #14
Oldenslow   Oldenslow is offline
It is a single-cylinder engine hard-mounted in a light tubular steel frame. It is going to vibrate as long as it is running.
