Old 08-25-2017, 03:42 PM   #1
jatgm1   jatgm1 is offline
smog blockoff plate for cg250 emissions plug
Where can I get a plate to cover the hole where the emissions control system comes off the cylinder head? Apparently it's a thing u can get for bikes but idk where to get one for a cg250 engine.
Old 08-25-2017, 04:21 PM   #2
I don't think you will find one. Most on here just fabricate one out of steel or aluminum.
Old 08-25-2017, 05:19 PM   #3
fishman10   fishman10 is offline
fishman10's Avatar
Block off plate
I made mine out of a piece of the crate the bike came in.
2015 zongshen rx3,,(Sold),,,2016 bashan storm,,2005 Harley ultra classic.
Old 08-25-2017, 05:40 PM   #4
goat67   goat67 is offline
goat67's Avatar
I used a rubber cap you can find them at the auto parts store.
2016 Brozz
Old 08-25-2017, 08:27 PM   #5
How far apart are the bolts on these? Would this work? http://www.ebay.com/itm/311298248082
It looks similar. I have a piece of hose with a bolt in one end that's hose clamped on to it but it looks like shit. I don't wanna jury rig it.
Old 08-25-2017, 09:09 PM   #6
elevatorman   elevatorman is offline
Evap block off plate, from Cleveland Cycle werks.
$14.95 but not currently available.
Old 08-25-2017, 09:10 PM   #7
fishman10's Avatar
Block off plate.
That's alot of money for something you can make for free,,,,just trace the plate you took off including the bolt holes,, transfer that to a piece of metal. An cut it out .
Old 08-25-2017, 09:28 PM   #8
Well I don't really have metal I can use lying around.
Old 08-25-2017, 09:35 PM   #9
fishman10's Avatar
Block off plate
You only need a very small piece ,,guarantee if you trace it on to paper an show it to a garage or welding or machine shop ,,, they will probably give you a small scrap piece,,
Old 08-25-2017, 09:45 PM   #10
goat67's Avatar
Here is a link to what I used
https://smile.amazon.com/Dorman-Help-41050-Vacuum-Asst/dp/B000COB5TE/ref=pd_sbs_263_9?_encoding=UTF8&psc=1&refRID=WCBRB 3KNV68Q2SY08PVS
I also took a tie wrap and used it to tighten it down a clamp would also work.
2016 Brozz
Old 09-26-2019, 04:03 PM   #11
CaesarVis   CaesarVis is offline
I know this is an old thread but I was searching for a plate too. I would suggest that if you use a vacuum cap you also shove some folded up/rolled up aluminum foil down into the "J-shaped" pipe before putting the cap on it. I would imagine hot exhaust will eventually melt or ruin the rubber...
Old 09-26-2019, 04:22 PM   #12
wedooit   wedooit is offline
wedooit's Avatar
keep it all china syndrome!!!!! my mrs commandeered the steel off of our crate to build a project!!!
A family that works together, plays together, shoots and trains together, and sleds together, stays together. Second amendment! SkiDoo sleds, NOW 2 TTR225, and a BMS250. A couple of quotes (we are not farmers) "I don't get off the farm much" "Am too old school" I call the china bikes "the china syndrome".
Old 09-26-2019, 05:22 PM   #13
AresROC   AresROC is offline
AresROC's Avatar
Tako aka NzBrakelathes says he has them but I havn't seen the link...
My Version...
BaShan BSR 250 DB-41H 2018 Red BS250GY-18D
JFG Racing Exhaust . Adjustable Shock 320mm . Brozz Digital Gauge . Renthal Fat Bar . 428 17x46 Sprocket . Fender Eliminator . Wheel Truing . Fuel Tank Repair .
Keihin PZ30 Main-115 Pilot-38 Needle-1Washer Fuel Mixture-1/2
BSR Chronicles - "Project leads to more projects!"
Yamaha WR250R
Suzuki GSX-R 600
Old 09-26-2019, 07:45 PM   #14
Armycopter   Armycopter is offline
Armycopter's Avatar
Just curious what the advantage is to removing the whole assembly and blocking it off? Does it hurt anything to keep it connected?
Old 09-26-2019, 09:32 PM   #15
Its worth removing if you change the exhaust or decat the factory system. Unless you like hearing pops, bangs, and spitting flames and burning out any muffler packing hou might have.
