07-31-2017, 03:09 PM | #151 | |
http://www.sears.com/craftsman-5-pc-...p-00941715000P
07-31-2017, 06:25 PM | #152 |
Are you planning to go with less aggressive tires? I've wondered for awhile if some Shinko 705s combined with carb and exhaust would finally give 65mph cruising ability on flat land.
07-31-2017, 07:22 PM | #153 |
Tires might make a slight difference. Dropping my bike down to a 41 or 39 tooth would probably have a better chance of seeing that type of cruise speed.
08-01-2017, 09:13 PM | #154 |
Dan, I can tell you from personal experience with my Hawk that running the 39T rear sprocket will get you up to about 68 mph at about 6,200 RPM. I bounce off of 70 occasionally, but the bike is really too light for those kinds of speeds. I get some really wicked headshakers going on after about 62-65. Any small upset in the road surface causes huge oscillations back through the handlebars. I'm sure most of that will disappear once I burn through the stock knobbies and get some more street-oriented tires on, but for right now I treat the Hawk like my Ural: It will do 55 forever, 65 occasionally, and 75 once (Usually over a cliff....) Just my thoughts on what I know with my bike, your mileage may vary.
08-01-2017, 10:20 PM | #155 |
I get zero headshake or other stability issues at or past 65mph and I am still on the knobbies. Might want to check your wheel and/or headstock bearings or front wheel trueness and balance. My only enemy is the wind.
08-03-2017, 06:37 AM | #156 |
Dan, front wheel is true and balanced, and the head bearings are greased and tight. Not sure where the headshake (oscillation, really) is coming from, but I know I run higher tire pressures, and that likely has a lot to do with it. I just keep it down around the 55-60 mark and I don't have any problems. It's a super fun bike to tool around on, and if I need to do any serious overlanding I take out the DR. I'm going to need to take them Missus bike out today. It has 67 miles until the 1500mi oil change. I want to get that done before we go to Arizona. Have a great day everyone.
08-03-2017, 07:33 PM | #157 |
Honestly, I don't want or desire the ability to go past 60-65 on this bike anyway. As you said, it's such a light bike, and being so tall and not very aerodynamic, it is already a bit of a handful as it is.
Personally, I am quite happy with the 17/43 gearing now with the mods on the bike. The exhaust and intake really woke up the bike across the rev range. Before the gearing felt too tall and almost anemic at slow speeds, but now it can throw me back pretty good in the low gears and has the top end to achieve the cruise speed I am most comfortable with on the bike for how I use it - 60mph for short jaunts, but still has plenty of get-up-and-go for around town and dirt roads/light trails. As eveRide would say, it has better tractor factor. Honestly, the only reason I would put a 39 tooth rear on the bike would be specifically to take some kind of longer trip, and mainly to get the rpms down a bit more. To answer the tire question, I have two tires in mind. As much as I would love to put some road only tires on it, I did buy this bike with the idea that it would see some trail use. With that in mind I am currently torn between two tires. First tire is the Shinko 700 in 3.00x21 front and 4.6x18 rear. It's the more aggressive of the two being a 60/40 tire, but all of the reviews on it show that it meets the general requirements I am after. Decent wet weather, good in a majority of dirt scenarios aside from deep sand and mud (which is common for most 50/50, 60/40 tires anyway). The second tire is the Avon AV53/AV54 trail rider 90/90-18 front and 120/80-18 rear. Being a 90/10 tire, it would be the best for on-road use. Rave reviews on it for it's road manners, while obviously the off-road capability is pretty much dirt and gravel roads. Both tires and their respective sizes are rated for the rim widths of the Hawk by the manufacturers. The only real difference is price. I can buy both Shinko 700's for the cost of just one Avon tire. However, the Avons were designed for more much powerful and heavy bikes and have incredible mileage capability, aka they last a while. Most likely I will go with the Shinko 700 simply because of the cost, and once they wear out I may give the Avons a try. Interestingly, the 700's have better on-road reviews than the 705's, which is why I decided to go that route. The only thing the 700's seem to really suffer from is a little more vibration, which I can live with.
Hawk Information and Resource guide: http://www.chinariders.net/showthread.php?t=20331 2018 Hawk 250 - Full Mod list here. http://www.chinariders.net/showpost....62&postcount=1 2024 Royal Enfield Shotgun 650 https://chinariders.net/showthread.php?t=34124 Last edited by Megadan; 08-03-2017 at 08:25 PM. |
08-04-2017, 01:31 AM | #158 |
And they lock up under brakes quite easy on lose surfaces..
i am on my 3rd set of 700s on my XT660R... but then the XT is a bigger heavyer bike to stop in a hurry as well as having a 320mm front disc rotor.. ..
08-04-2017, 06:53 AM | #159 | |
In other news, I went ahead and ordered one of these guys. https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1 The irony of spending more on the adapter than I paid for the carburetor. is not lost on me. Admittedly, I didn't actually pay for the carburetor directly, but it is still funny. I had the option between that and a slightly bigger unit designed for up to 34mm carbs. This one is a bit smaller with the inlet size reduced to 28mm, but the mounting flange options mean I can either try it on the stock intake, or directly to the head, plus I can always machine out the center to 30mm. This one also works with the carb I currently have without needing to buy a reducer/adapter.
08-06-2017, 02:57 AM | #160 |
So, here are my options and drawbacks with:hmm this adapter.
Option 1. Mount it directly.to the head. Pros. -The carb is close to the intake port with a straight ahot in. -likely the easiest way to fit it and will clear frame. Will also make pod filter sit more inward. Cons. - Carb is angled back more than I would like. Not a deal breaker, but will possibly require adjusting float level to compensate. I do happen to have a 15 degree rotax carb socket that would work perfectly, but it is designed for 38 to 40mm carbs, so it will not work with the 30mm oko or Adapter I purchased. I would love to find one like this for 35mm spigot diameter, but I haven't had much luck.
08-06-2017, 03:10 AM | #161 |
Option 2; Mount it to the exiating intake.
Pros. - Angle of carb will be more level. Cons. - Intake run from throttle slide to intake valve will be a bit longer. This may not really be a bad thing per-se, but it just represents potential turbulence/restriction. -Fitment may prove to be an issue in regards to the air cleaner side of things as the inlet of the carb will move further out and forward. I have a few simple ideas to solve this, but compared to the bolt to head approach it requires extra work.
08-06-2017, 05:40 AM | #162 |
Only use it for riding up hills the carb will always be level...
it's not really a issue... but you could make a wedge shaped spacer ... or mill the face of the manifold on a angle... .....
08-12-2017, 06:20 AM | #163 |
Those are options, but I decided to go a slightly different route. I went ahead and setup an exchange on this adapter for the larger unit and I am going to bump up to the 32mm OKO. This will give me the spigot diameter to work with the Rotax carb boots I already have.
From previous experiences on other bikes with similar cylinder sizes I don't expect it to misbehave, but I do see the biggest issue being the port restriction on the stock head since it is only 30mm. I will test it out on the stock head, and see how it behaves. Obviously if I don't like it I will simply convert back to the Fakuni until I can get around to doing the ported cylinder head, which I can port match and blend the extra 4mm diameter of the flange with a taper. I can always go back to the 30mm idea if the 32 doesn't work out, but it will take a lot more time and effort to try and sort that out. As I said, from my previous experience with similar cylinder sizes, the engine should respond rather well across the rev range, but until it can be put into practice it is all just speculation at this point. Worst case scenario would be a small loss in the lower revs and a gain up top with a marginal effect on throttle response (being a bit more touchy). Given my riding style and use of the bike I personally wouldn't mind that trade off. Best case scenario, and something I have experienced in the past, would be a strong gain in the mid-range and top end. This has been evidenced on GL1000 enines, which run a 32mm carb with a 28mm venturi that step up to a 35mm down-drafts with a 32mm venturi, and especially on a 40mm carbs with a 35mm venturi. While obviously apples to oranges, the individual cylinders are similar in displacement, 2 valve heads, and have an identical powerband and rev range. So it makes me optimistic. If I end up with the same kind of powerband (useable from idle to 3000, good from 3000-4000 and strong from 4000-8000) then I will be plenty happy. Guess I will find out.
08-13-2017, 01:52 AM | #164 |
When I see Rotax I think rotary valve engine. Not that a hose won't work but I am curious.
08-13-2017, 02:24 AM | #165 |
Certain Skidoo and Polaris snowmobiles and watercraft used a Rotax engine in them that had angled carb boots to help level out the carburetors. I initially bought them attempting to find a solution to an ITB setup for my Goldwing, but decided to go a different route. They are just about the perfect angle to make the carb and adapter work on my Hawk, and not too hard to find. If I can get it to work, then I will definitely post up the model they came from.
