Old 06-06-2017, 09:39 PM   #1
jfeliciano15   jfeliciano15 is offline
Lower Fork Covers for Hawk
Anyone know if there is a fork cover that will best fits a Hawk?
I have been searching for a pair of the Brozz fork covers but can't find them for sale.
Old 06-06-2017, 11:49 PM   #2
hertz9753's Avatar
Measure the width of top tube and lower tube. After that it is the length you need for your bike. They are called fork boots or gaiters.
Old 06-07-2017, 01:00 PM   #3
I'm talking about the piece that goes outside of the fork made of plastic or carbon fiber.
Kind of like a shield for the front of the fork. Gaiters is not what I'm looking for.
Old 06-07-2017, 01:46 PM   #4
Those types are guards are common on USD forks to protect the fork seals and inner tubes, because they are directly exposed to just about the worst place possible. Facing down and forward.
You generally don't see them on traditional forks, because there is nothing there to protect. The biggest, strongest part of the fork is at the wheel, and the seals face up and away from the path of most debris. Instead, traditional forks use gaiters to perform the same function.
Old 06-07-2017, 08:37 PM   #5
Brozz has them on the fork and I just like that look. That's the only reason why I'm looking to install them on my hawk.
Old 06-14-2017, 10:43 PM   #6
linemanxxlog   linemanxxlog is offline
I would buy them too just for the looks if I could find them
Old 06-14-2017, 11:49 PM   #7
hertz9753's Avatar
Those plastic fork guards will not work with standard forks. They would have to attach the lower tubes and break on the bottom of the fender. On inverted forks they travel down toward the axle and don't have anything to run into.
Old 07-16-2017, 03:48 PM   #8
I managed to install a pair and just want to know what you guys think
Old 07-16-2017, 04:01 PM   #9
My apologies for how the pics are displayed but I can't figure out how to correct it. I drilled a hole on the inner side of the cover and attached it using the screw that holds the bracket for the speed sensor & front brake line. I also used zip ties on the lower part of the cover to hold on to the bottom of the fork so that I can avoid any vibration. It is working fine so far.Yay!!
Old 07-16-2017, 04:28 PM   #10
By the way I am also a rotary Head just incase you're wondering why I put a rotary decal.
(1985 Mazda Rx7 12A Turbo).
Old 07-18-2017, 07:29 AM   #11
Thanks for the thumbs up Jerry, Chuck and Wamey
Old 07-18-2017, 08:29 AM   #12
Your welcome. You have the same philosophy that I have. There's no such word as the word 'Can't" Anything is possible if you put your mind to it.
Old 07-20-2017, 04:23 PM   #13
4 days since I installed them and no problems at all, even after running into some nasty potholes they held up perfectly.
