Old 06-27-2017, 07:28 PM   #16
Try to trace where the black wire goes. On most reg/recs a black wire is used as a sense wire. Not all have them as many newer designs are self sensing/regulating. On my goldwing I simply capped the sense wire off on the chassis harness when I upgraded to a newer combined unit.
Old 06-27-2017, 09:52 PM   #17
Looks like you are right, it is a sense wire that is switched with the ignition switch.
http://www.chinariders.net/attachmen...1&d=1458014563
Old 06-27-2017, 10:12 PM   #18
dpl096   dpl096 is offline
dpl096's Avatar
Good pickup Megadan....this tip should help plenty of others! Well done to both.
― Thomas Jefferson
Old 06-27-2017, 11:25 PM   #19
All wired up and running, voltage is between 14.1v and 14.3v. No more exceeding 15v and no more below 13v.
Old 06-28-2017, 12:49 AM   #20
Glad to hear it. I have found that blanking the sense wire and upgrading the reg rec makes for much more consistent and stable charge voltage, especially at low rpm.
Did you end up with it in the stock location or try to relocate it at all?
Old 06-28-2017, 01:53 AM   #21
I couldn't find a good location for it other than stock so it is in the stock location.
Old 06-28-2017, 04:28 AM   #22
I will be following in your footsteps with this upgrade as well. Honestly, the one thing I don't trust on my Hawk is the electrical side of things. I am sure it's fine, but...
Old 06-28-2017, 12:37 PM   #23
I've found that the China R/R can drain the battery when it goes bad. Perhaps that's another reason for the sense wire, but I suspect it would kill the battery anyway.
I'm quite intrigued by this new R/R; may we see a pic of it installed?
Old 06-28-2017, 01:12 PM   #24
Rangerscott   Rangerscott is offline
Its a well known swap in the jap bike scene. I need to swap out the older fh011 I have on my vfr for the smaller newer one.
Old 06-28-2017, 04:40 PM   #25
Next time I have the tank off. It was late and the sun was low when I finished so I didn't take any pics.
