06-08-2017, 11:50 AM | #16 |
Ok. Looks like I'll be making one.
FYI. Heres a metric to inch bolt grade reference. Metric 10.9 is grade 8. https://www.google.com/search?q=grad...l3CEi1eE3IfYM: |
06-08-2017, 12:02 PM | #17 | |
06-08-2017, 05:38 PM | #18 |
Can you get me the thickness of that second special washer?
06-09-2017, 09:03 AM | #19 |
Ah sorry man, I have the motor completely back together now and gave back the flywheel puller I borrowed. If I recall correctly the second washer was only half the thickness of the other. Just enough to give an 1/8" I'd say of clearance between the gear and the flywheel. Hope that helps. You might get away with using an off the shelf 7/8" ID spacer washer which is just a hair bigger than the shaft.
