05-29-2017, 07:55 AM | #91 |
I was going to drill all the pretty holes and thought about defeating the whole purpose I was putting the skid plate on in the first place. With the luck I have the first ride out on a trail a branch will pass right through one of those holes and shish kabob the oil hose. Besides when I go to fry an egg it will run through the holes. Man after looking at the picture I just realized I never washed the bike from the last trip I made. Too many irons in the fire including the skillet skid plate .
2024 Linhai 300 ATV 4x4 2023 Lifan Lycan 250 Chopper 2023 Venom Evader 2022 Lifan KPX250 2020 Kawasaki Vulcan S (Sold) 2004 Honda ST 1300 2016 Black Hawk 250 (sold) Keihin PE30 carb,125 main,38 slow.Pod filter,ported & decked head 10:1 CR,Direct Ignition Coil,15/40Sprockets,NGK DPR8EIX-9,De-Cat,Dual Oil Cooler,Digital Cluster 2016 Cazador180 XL 2014 Coolster150 JerryHawk250.com My YouTube Channel Last edited by JerryHawk250; 05-29-2017 at 08:54 AM. |
05-29-2017, 09:10 AM | #92 |
Skillet Skid Plate!
JerryHawk250 you have just named your creation! You should patent that name!
05-29-2017, 09:34 AM | #93 |
LOL. I do plan on extending the sides out more and do something similar to what Chuck did. First I wanted to do something simple to show the average guy who don't have Welders or welding skills can do. All that was needed was a grinder, jigsaw and drill. You can go to any fabrication shop and have them cut you a piece to size for little or no money. I have all the tools equipment, Welding machine and skills to make something more complicated. Aluminum could be used instead but will have to be careful not to Crack the aluminum when making sharp bends.
05-29-2017, 11:19 PM | #94 | |
Do you have the link to the version of the oil cooler with the stacked plate cooler? Also, did any one else have a problem having the page from the link no translating? |
05-30-2017, 08:11 AM | #95 | |
View the TaoBao site with Google Chrome to translate it.
05-30-2017, 12:18 PM | #96 |
Aluminum is much easier if you anneal it first. All it takes is a bar of soap and a propane torch. Google is your friend.
05-30-2017, 01:04 PM | #97 |
Thanks for the info. I may remake it in aluminum later on. I was thinking I would have to do some welding was the main reason I went with steel. My welder is set up for stainless and steel right now and didn't want to have to set everything back up for aluminum. I have lots of aluminum wire but no shield gas.
2024 Linhai 300 ATV 4x4 2023 Lifan Lycan 250 Chopper 2023 Venom Evader 2022 Lifan KPX250 2020 Kawasaki Vulcan S (Sold) 2004 Honda ST 1300 2016 Black Hawk 250 (sold) Keihin PE30 carb,125 main,38 slow.Pod filter,ported & decked head 10:1 CR,Direct Ignition Coil,15/40Sprockets,NGK DPR8EIX-9,De-Cat,Dual Oil Cooler,Digital Cluster 2016 Cazador180 XL 2014 Coolster150 JerryHawk250.com My YouTube Channel Last edited by JerryHawk250; 05-30-2017 at 02:52 PM. |
06-01-2017, 01:19 PM | #98 | |
Thanks. All i use on this PC is chrome and every time i translated it it would stay the same. |
06-01-2017, 01:31 PM | #99 |
It will only translate the text. Anything that is in a picture will not translate.
06-01-2017, 02:17 PM | #100 |
06-01-2017, 02:31 PM | #101 | |
06-02-2017, 12:04 PM | #102 |
How does oil flow through this
06-02-2017, 01:10 PM | #103 |
The oil pump sucks it threw the oil line and cooler then returns back to the base.
2024 Linhai 300 ATV 4x4 2023 Lifan Lycan 250 Chopper 2023 Venom Evader 2022 Lifan KPX250 2020 Kawasaki Vulcan S (Sold) 2004 Honda ST 1300 2016 Black Hawk 250 (sold) Keihin PE30 carb,125 main,38 slow.Pod filter,ported & decked head 10:1 CR,Direct Ignition Coil,15/40Sprockets,NGK DPR8EIX-9,De-Cat,Dual Oil Cooler,Digital Cluster 2016 Cazador180 XL 2014 Coolster150 JerryHawk250.com My YouTube Channel Last edited by JerryHawk250; 06-05-2018 at 11:53 AM. |
06-03-2017, 05:53 AM | #104 | |
I guess i will take a screen shot later and post it. Nothing will translate. Not one word anywhere one the page. |
06-03-2017, 08:26 AM | #105 |
You may need to update chrome or just use a different pc.
