Old 06-01-2017, 04:09 PM   #1
joker   joker is offline
Oh No Brozz electrical issue!
Hello so I just purchased a new battery but for some reason I can't get any power. I can kick start the bike and everything lights up but no power when I turn the key and use the battery to start it. Please any suggestions?
Old 06-01-2017, 04:14 PM   #2
Check all connections from the starter button to the connection to your starter solenoid and make sure there is power going to it when you push the starter button. Does the Brozz have a safety switch on the kick stand? might check that too if it does. There should be 2 red wires on the positive post of the battery. one with a fuse and the other to the solenoid. Make sure they are both hooked up.
Old 06-01-2017, 04:51 PM   #3
I checked the ground which was I think a green wire under the gas tank connected to the spark plug module. I took it off and I was able to start the bike by kicking it over, everything lit up when the bike started, I was also able to use the electric start when the bike was running. It's got to be something that just has to do with the connections to the battery
Old 06-01-2017, 05:04 PM   #4
Could be one of the safety switches like clutch lever switch, neutral switch.
Old 06-01-2017, 05:25 PM   #5
Just thought of something. Doesn't the Brozz have a remote start? I know some have had issues with it.
Old 06-01-2017, 05:33 PM   #6
Ok so far I've checked the grounds on the plug and on the starter, along with the clutch switch. Neutral switch idk how to check although the green neutral indicator light is on when in neutral. Any other ideas?
Old 06-01-2017, 05:35 PM   #7
It does have the remote! I wonder how I would go about adjusting it
Old 06-01-2017, 05:45 PM   #8
Temporarily disable the remote and see if that works. See this thread. http://www.chinariders.net/showthrea...ghlight=remote
Old 06-01-2017, 06:55 PM   #9
Ok so I disconnected the remote and alarm exactly how that thread showed. When I kick the bike over to turn it on it starts fine runs and idles. When I turn the key off then back on the guage cluster flashes blue then turns off. How can I upload a video to show exactly what it's doing?
Old 06-01-2017, 07:30 PM   #10
BigWeld   BigWeld is offline
BigWeld's Avatar
This might sound stupid, but did you put acid in the new battery, and allow it to "soak" before charging it with only 1 or 2 amps?
Rides a 2016 Bashan 18C with Blue PlastiDip, piped and jetted, USB charger, real-time digital volt meter, faux carbon fiber handguards, 5 COB led headlight upgrade, auxiliary led light bars, and an MSR shift lever with new grips, T6 aluminum handlebars anodized in blue, polished handlebar brace, decals, HD Unibear chain and spoke covers waiting on the always-full mod shelf......
Old 06-02-2017, 11:48 AM   #11
Yes haha I did I also purchased a brand new maintenance free battery. I read the wires going into the harness from the battery might be too thin to let the voltage threw. If I turn the bike on by kicking then turn the key off and back on, the rpm guage will light up for a split second then turn back off.
Old 06-02-2017, 11:51 AM   #12
Did you check the fuse?
Old 06-02-2017, 01:59 PM   #13
Where would that be located? I really appreciate your help!
Old 06-02-2017, 02:02 PM   #14
it should be right by the battery on one of the red wires. Mine is in a white housing.
Old 06-02-2017, 02:05 PM   #15
Thank you I'll check once I'm out of work!
brozz, hawk
