Old 05-19-2017, 12:25 PM   #31
Originally Posted by rvl8rida View Post
getting back to the main topic for a second, sorry.
Does anyone know for sure that this will fit the mikuni carb we all buy on ebay?
if i burn myself on my exaust one more time trying to get the mix right, im going to roll my bike off a cliff.
http://www.ebay.com/itm/Air-Fuel-Mix...%257Ciid%253A1
I ordered one of those for my VM26, but I am still waiting for it's arrival. I can definitely let you know for sure once it comes in.
Originally Posted by GeneralTso View Post
I agree the front is easier to swap but I was seeing where I might have clearance issues with a 17 in the front.
Good discussion though because I want to get this right.
Well, the nice thing about sprockets is, they aren't overly expensive or difficult to change, especially going down in tooth count. Just try to figure out what gear ratio is ideal for your bike, you (weight etc), and it's use. For road use, I would try to gear it so that the revs in 5th gear sit right around where torque peak is at whatever MPH you want it to cruise at. This may make the bike over geared as far as top speed, and kill a bit of the acceleration, but I would rather not sit at redline to go 60mph. Plus, generally an engine is it's most efficient around it's peak torque RPM, because that is the point where VE and Intake velocity are at their highest, usually giving the most clean burn.
I think the 46 rear is a good starting point for what you want. It will put you right at 3.07. Then, if you want to go a little taller, try a 16 front, shorter then your 14 front. Going in either direction wouldn't require changing the chain links either as it's only a +1 or -1 front. That would give you a 2.88 and a 3.29 respectively. That's why I suggested the rear first.
Old 05-19-2017, 01:06 PM   #32
Ariel Red Hunter's Avatar
Yes, it fits...ARH
Old 05-19-2017, 04:44 PM   #33
same thing a little cheaper. http://www.ebay.com/itm/252822244650...84.m1436.l2649
would these fit the oem shenway carb on the hawks?
2016 hawk
kaw h1 400 tripple
13' long chopper in progress
2009 johnny pag bar hog
Old 05-19-2017, 04:50 PM   #34
I was wondering the same thing.
Old 05-19-2017, 06:41 PM   #35
da4design   da4design is offline
da4design's Avatar
yep they fit the mikuni carb, and so much easier to adjust
http://www.chinariders.net/showthrea...180#post255180
Old 05-19-2017, 09:58 PM   #36
but will they fit the oem shenway?
2016 hawk
kaw h1 400 tripple
Old 05-21-2017, 08:31 AM   #37
GeneralTso   GeneralTso is offline
GeneralTso's Avatar
So ordering the sprocket was a little more than I thought it would be. All the sellers were in Europe lol, finally found on on eBay, 45T. Can't wait to get it on and see the difference it makes.
2005 Kazuma Cheetah 200 (Swamp Thing)
Old 06-01-2017, 04:56 PM   #38
GeneralTso's Avatar
Well I got the Mikuni on and what a difference, bike runs so much better. Smoother acceleration, no break up what an improvement.
Next I have to swap out the sprockets and see how she does on the road with the better gearing for street use.
And yes I got rid of the choke cable, that little flipper on the carb is in perfect position to just reach under and adjust.
Old 06-01-2017, 10:38 PM   #39
pistolclass's Avatar
Totally agree the Mikuni upgrade was a great improvement on my hawk (110 pilot).
Old 06-03-2017, 10:41 AM   #40
GeneralTso's Avatar
I am loving this new carb!!
Old 06-04-2017, 12:31 AM   #41
JeremyC   JeremyC is offline
I kept the stock 15T front sprocket and changed to a 45T rear. I like it so far.
Old 06-04-2017, 11:05 AM   #42
BigWeld   BigWeld is offline
BigWeld's Avatar
You might have an easier time with an old XR200 plastic tank, since the frames are so similar.
I just did a quick eBay search on these, and the shapes and sizes varied two or three times though the years....any idea which year's tank fit best for our application?
Rides a 2016 Bashan 18C with Blue PlastiDip, piped and jetted, USB charger, real-time digital volt meter, faux carbon fiber handguards, 5 COB led headlight upgrade, auxiliary led light bars, and an MSR shift lever with new grips, T6 aluminum handlebars anodized in blue, polished handlebar brace, decals, HD Unibear chain and spoke covers waiting on the always-full mod shelf......
Old 06-05-2017, 12:28 PM   #43
Not a clue; it's only a guess. The ultimate scenario would be to find a friend with an XR200 and borrow his tank for fitment testing.
