05-27-2017, 10:51 AM | #1 |
Hawk CDI upgrade question
Has anyone done a CDI upgrade on the Hawk 250 and if so what CDI unit did you get? Also was it plug and play or did you have to do some wiring reconfiguration?
05-27-2017, 10:41 PM | #2 |
I was looking into that too. Most of the name brand companies are to expensive and I don`t think that they make a model for our Chinese bikes. I did see one for a Chinese moped/scooter and it was fairly cheap. Keep us posted if you find something that works.
05-28-2017, 01:57 AM | #3 |
Some people have tried but it didn't work out.
05-28-2017, 07:26 AM | #4 |
Yeah, I remember reading that not only is the timing retarded too far in those cheaper units for easy starting, but it's benefits are barely worth the trouble of installing it. Trouble is (I think) that it's not variable. What I mean is, your timing needs to change at different rpm for maximum performance, but these cheap chi units can't physically do it and even if they could, they're not adjustable
Rides a 2016 Bashan 18C with Blue PlastiDip, piped and jetted, USB charger, real-time digital volt meter, faux carbon fiber handguards, 5 COB led headlight upgrade, auxiliary led light bars, and an MSR shift lever with new grips, T6 aluminum handlebars anodized in blue, polished handlebar brace, decals, HD Unibear chain and spoke covers waiting on the always-full mod shelf...... |
05-28-2017, 10:45 AM | #5 |
Not worth it. Mine went in the garbage.................
05-28-2017, 08:31 PM | #6 |
Thanks for all the feed back and I will let you guys know if I find a way of making this happen. Enjoy the holiday!
05-30-2017, 08:34 AM | #7 |
Here's a link to the cdi unit that I was looking at:
https://www.vmcchineseparts.com/coll...nce-version-43 I haven't looked to see what plug configuration our Hawks have. Keep us posted on what you find out.
05-30-2017, 08:55 AM | #8 |
A programmable CDI will be the best one to get if you can get one. I've been trying to get this one but having a hard time getting any information on availability or cost. http://www.dansgaragetalk.com/topic/...-time-mapping/
Additional Info- I found where to buy the programmable CDI for under $85. https://www.aliexpress.com/item/Digi...e-dc34455d668e
2024 Linhai 300 ATV 4x4 2023 Lifan Lycan 250 Chopper 2023 Venom Evader 2022 Lifan KPX250 2020 Kawasaki Vulcan S (Sold) 2004 Honda ST 1300 2016 Black Hawk 250 (sold) Keihin PE30 carb,125 main,38 slow.Pod filter,ported & decked head 10:1 CR,Direct Ignition Coil,15/40Sprockets,NGK DPR8EIX-9,De-Cat,Dual Oil Cooler,Digital Cluster 2016 Cazador180 XL 2014 Coolster150 JerryHawk250.com My YouTube Channel Last edited by JerryHawk250; 05-30-2017 at 01:20 PM. Reason: Found where to buy |
05-30-2017, 10:55 AM | #9 |
The CDI that JerryHawk250 was looking at is a better unit. The one I was looking at is more like an MSD Ignition box.
05-30-2017, 11:02 AM | #10 | |
Edit: will not work. DC CDI. Hawk requires AC CDI
2024 Linhai 300 ATV 4x4 2023 Lifan Lycan 250 Chopper 2023 Venom Evader 2022 Lifan KPX250 2020 Kawasaki Vulcan S (Sold) 2004 Honda ST 1300 2016 Black Hawk 250 (sold) Keihin PE30 carb,125 main,38 slow.Pod filter,ported & decked head 10:1 CR,Direct Ignition Coil,15/40Sprockets,NGK DPR8EIX-9,De-Cat,Dual Oil Cooler,Digital Cluster 2016 Cazador180 XL 2014 Coolster150 JerryHawk250.com My YouTube Channel Last edited by JerryHawk250; 02-03-2020 at 04:57 PM. |
05-30-2017, 12:13 PM | #11 |
Efi
JerryHawk250...tell us about this EFI you speak of! This isn't one of those EFI systems that cost more than the Hawk itself is it?
05-30-2017, 01:08 PM | #12 |
Having trouble finding brozz upgrades
Hello all I'm trying to find some info on upgrading my 2016 brozz. the carb, rear drum, a battery (mine won't hold a charge) and also an exhaust with a new header. My bike currently has 560 miles and climbing. No issues so far with the bike, although I've had to adjust the valves about 4 times and the battery not working.
05-30-2017, 01:15 PM | #13 | |
05-30-2017, 08:27 PM | #14 |
Hey JerryHawk250,
When you start your EFI conversion, you will have to start a new thread/post...with lots of pictures! You should start the thread/post when you place the order.
