03-15-2017, 01:13 AM | #5 |
The CSC uses a square bore engine and is counter balanced. It claims about 16 HP and the Hawk engine doesn't have that and is about 14 HP. Both are good engines but different.
03-15-2017, 03:29 AM | #6 |
67x65= 229cc
70x65= 250cc 21cc or 11% more. could be good for another 1.5/2hp .
03-15-2017, 09:12 AM | #7 |
67mm bore by 65mm stroke. A 70mm bore on that same stroke is close to 250cc. A 10% improvement in displacement. Should give a 10% improvement in torque. And at least that much of an improvement in HP. The question is if the cases and the case bolt pattern will cover a 70mm bore....ARH
04-04-2017, 06:35 AM | #8 |
I am not quite sure about it. return man 3
04-04-2017, 05:15 PM | #9 |
What are you not quite sure about?...ARH
04-04-2017, 05:34 PM | #10 |
I recall there being a 177FMM??? (77 being the bore). I'm not sure if it was water cooled or not.
W&G or culcune or some other CR old-timer will know better than I, if they chime in.
04-05-2017, 11:03 AM | #11 |
I only ever saw large-bore engines like that on Taobao. It's tempting, but I'm not going to order one.
