Old 03-18-2017, 12:55 PM   #1
TheGageinator   TheGageinator is offline
Non replaceable ball joint 200cc SunL
Check these out. looks like I'm going to have to buy new a-arms because the ball joints cannot be replaced :(
Old 03-18-2017, 01:07 PM   #2
Bruce's   Bruce's is offline
Generally they are just tack welded in there ,if you can break that Weld there is a good chance you can find another bj to go in to the arm .I have done a few with no issues .
Old 03-18-2017, 04:33 PM   #3
I agree with Bruce. I can't see from the pictures where the welds actually are. Start pressing/beating them out and you might be surprised how easy they come out.
2012 Kawasaki Versys
1984 Honda Magna V65
2016 Rhino 250
2016 Tao Tao 125D
Old 03-19-2017, 12:16 AM   #4
Adjuster's Avatar
Impact air hammer will knock it right out if you can get it braced solid.
Old 03-19-2017, 12:24 AM   #5
So you guys think that the part circled in red will come loose and come upward? I really don't think it will. What is holding it in? A seem weld? The replacement ball joints I've seen use a snap ring
Old 03-19-2017, 09:02 AM   #6
It might be welded ,pressed in ,or who knows ? ,it's hard with the limited pictures to see what's holding it in ,but with a little work It will probably pop out .
Old 03-19-2017, 10:52 AM   #7
ben2go   ben2go is offline
If there's a snap ring. It will be on the spindle side. Those are pressed in from the back to prevent damaging the ball joint and tapered stud mount. They should press right out. You'll need to find a shop with at least a 20-ton press. It shouldn't cost much to have a good auto shop press them out.
Old 03-19-2017, 11:10 AM   #8
Azhule   Azhule is offline
Have you pulled that rubber boot all the way off the Ball joint yet (I seen you pull at it for the pic)? Usually you will find that 'Snap Ring/Retaining Clip' hidden under the rubber dust boot/grease seal... but I haven't worked on a SunL, so I'm not sure if it's the same or not?
A BFHammer or a Ball Joint Press usually works after you find/remove the Snap Ring... start soaking the parts in Kroil, PB'laster, Liquid Wrench, JB80, Pentro 90, Acetone/ATF Mix, etc... just soak the ball joint with some kind of good penetrating oil
Then lightly grease the hole and the new Ball Joint before you install... will make installing/removing this new one much easier
Old 03-19-2017, 12:32 PM   #9
There is not a snap ring under the boot. I'll put it on a press and see of it comes out but it appears welded all the way around. I'll run it the way it is for awhile and update when I put it on the press
Old 03-19-2017, 05:27 PM   #10
In the pic below, there appears to be a painted over dividing line between the BJ housing and the control arm. The factory may have popped a couple tack welds around it as a way to judge if the BJ is moving in the control arm.
Old 03-19-2017, 05:29 PM   #11
Also, have a look on aliexpress. I found a complete new front end cheap, on there for either an ATV or UTV.
Old 03-19-2017, 07:59 PM   #12
Thanks Ben, I'll check it out! If I can't get the ball joint out, I'll look at replacing the arms. I have it all back together now. The joints on the right side are really bad so I'll tear it apart again soon.
Old 03-19-2017, 10:13 PM   #13
You're welcome. I look forward to seeing your progress.
Old 03-20-2017, 10:57 PM   #14
07PSDCREW   07PSDCREW is offline
I suggest for the next ones, drilling the top and adding a zerk. I did that with mine. Uppers and lowers. They started to squeak bad but had no play. Threw a fitting on and wal la' fixed.
Old 03-21-2017, 08:06 PM   #15
Darth Racer's Avatar
I like that mod... will get around to doing that to mine at some point.
