#136 |
I should also add that I removed the float from the tank and plugged it in to the bike. I cycled the float from top to bottom with no change in fuel level or "low fuel " warning on the cluster.
#137 |
95, Glad you're keeping the bike. Once you get the kinks worked out you will know your bike inside and out (quite literally!). On the float issue, how long did you let it sit at each position? The float and gauge usually take a few seconds to a few minutes to update. You won't go through fuel at a rate as fast as you can move the float by hand, so it probably isn't programmed to recognize fast changes. That keeps the display from giving you false readings as the fuel sloshes around in the tank. I would say try it again, but very slowly, and see if the result is any different. Keep us posted on your progress.
#138 |
Very interesting. I hadn't thought about that but it makes sense. I'll go give it a shot
#141 |
Some of the better pics of the Hawk I have seen..
#142 | |
#143 | |
Thanks!
#144 | |
#145 |
So I had a buyer lined up, he ended up falling through last minute. Anyways, I decided (before that happened), I'd better make it function as good as possible so I went up to RPS in Carrolton, TX and paid $75 for a stator (that someone I know bought for $50 shipped to NY from the same guys
![]() ![]() ![]() Can you see why it stopped working? ![]() How about now ![]() Got the hand guards painted. ![]() Also added another bungee cord. The green one doesn't hold it up when practicing wheelies so a couple times I thought something was wrong with the bike when it was just the kickstand scrapping the ground lol!And yes, I will get an actual kickstand spring eventually ![]() |
#146 |
Do you intend to resolder and keep it as a spare?
#147 |
I do. Well, the new owner can if they wish. It might be sold tomorrow
#148 |
She gone. :(
![]() ![]() ![]() I loved is thing. I'll have another some day. |
#149 |
That was a good looking bike, hope you get another one soon.
Hawk 250 Mikuni carb 115 main. De-catted pipe. Air box mod. 15/42 sprockets. Digital instrument cluster, FMF end cap on muffler, handlebar toolbag, Custom foot pegs |
#150 |
I missed the reason why you sold it. Was it a flip thing?
