Old 01-17-2017, 08:23 PM   #1
hnu13   hnu13 is offline
Head Scratching LOUD backfire!!! Hawk 250
bike has a very loud backfire on deceleration..
- Mods -
stock pz30 carb
0.5mm overstock pilot jet
115 main jet
needle raised +2
mixture screw about 1 1/4 out
POD filter
spark arrestor out
baffle drilled out (about 8 holes)
cat removed
any ideas????
Old 01-17-2017, 08:57 PM   #2
Sport Rider's Avatar
did you check valve clearances?
Old 01-17-2017, 09:03 PM   #3
Azhule   Azhule is offline
Usually "Popping/Backfire on deceleration" means : Pilot jet too small or Mixture Screw is off (usually a bit lean)... might need to check valve clearances too
Also... according to "Mikuni"... "some heavily modified bikes (free flowing exhaust) will always have some kind of backfire/popping on deceleration"...
You might try 1 1/2 to 1 3/4 turns or more on the mixture screw... make sure you go no more than 3 turns out... go to a bigger pilot jet if you go 3+ turns out
Old 01-17-2017, 09:22 PM   #4
yes, just did them last week
Old 01-17-2017, 11:56 PM   #5
pete   pete is offline
pete's Avatar
air leak in exhaust most lightly..
air is getting in and igniting the unburn fuel
that gets in on a closed throttle....
Fuel / Heat / Air = BANG
It may have always done it... now yer gutted the muffler
& removed the CAT you can now hear it...
My XT660 pops/bangs like a bastard on a trailing throttle.
But it has a AIS (Air Injecton System) to let air in to burn the unburnt fuel....
Clean air bullshit and all that..
never head it till I put the Metal Mule pipe on...
09 XT660R ...
06 TTR250 ...
80 Montesa H6 125 Enduro...
Current resto projects..
81 Honda CT110...
80 Kawasaki KL250A1...
http://www.remotemoto.com/
E-mail... xtpete1@gmail.com
Old 01-18-2017, 07:30 AM   #6
I agree with Pete. Sounds like an exhaust leak.
Old 01-18-2017, 10:57 AM   #7
'16 TT250   '16 TT250 is offline
If the bike has PAIR (exhaust air injection) blocking it off may cure it. Assuming it's tuned right and there are no defects this will likely stop the pop. If it doesn't have PAIR then you might have an exhaust leak or it might just be going lean on decel, not uncommon.
Old 01-18-2017, 11:02 AM   #8
Originally Posted by hnu13 View Post
0.5mm overstock pilot jet...
Please explain what you mean.
Old 01-18-2017, 09:01 PM   #9
i drilled out the pilot jet to 0.5mm
Old 01-19-2017, 11:14 AM   #10
Thanks for the clarification. If I'm correct in my understanding, that equates to a #50 slow jet. Since the Keihin style uses much larger slow jets than Mikuni, I presume that size to be in the ballpark.
Do you have an air injection fitting or has it been blocked off?
Old 01-19-2017, 07:42 PM   #11
whats that? lol
but seriously, I'm not sure what that is.
Old 01-19-2017, 07:49 PM   #12
i not sure where it would be leaking? i removed the header pipe last night and re installed it to make sure everything was proper, and it looked fine..
Old 01-19-2017, 08:29 PM   #13
Did you replace the gasket?
Old 01-19-2017, 09:08 PM   #14
no sir.
to the head?
Old 01-19-2017, 09:18 PM   #15
no sir.
to the head?
Yes the one at the head
