01-13-2017, 06:25 AM | #1 |
hisun 800
have a 800 side by side hisun less than 500 miles had in 4 wheel drive once snowed over the weekend went to put it in 4 wheel would not go light just blinks on the dash where do i start cheched the fuses and connections
01-13-2017, 10:28 AM | #2 |
Is the 4wd manual shift or electric shift?
01-14-2017, 08:52 AM | #3 |
electric
01-15-2017, 01:12 AM | #4 |
Is it still under warranty? Call the place you bought it from or the distributor.
01-15-2017, 10:25 AM | #5 |
It's not under warranty. We bought it from a local cycle shop that picked it up at auction.
01-15-2017, 01:08 PM | #6 |
I know that Excalibur Motorsports used to distribute Hisun. Not sure if they will be able to help you out, but couldn't hurt to try?
909-591-8800
01-16-2017, 07:51 PM | #7 |
Electronic can freeze up easily, the most common solution, if no garage to thaw it, is to take a mallet and tap the front diff several times. This while 'rocking' the unit.
Regards, Dak |
