Coolster 3150-DX2 vs. Taotao 150 Bull
Hey guys, trying to decide between 2 near identical 150cc ATVs. Coolster or Taotao. I've researched that the coolster has a much bigger gas tank, holding nearly 2 gallons. The coolster also has an added kick start, in the event you're out wheeling and you get a short circuit you won't be stuck in the woods. And I believe the ground clearance is a little higher on the coolster. The new Taotao bull comes with led headlights. The coolster is a little more money and based on reviews has a sturdy frame. So based on you're own experiences, which is the better buy? Thanks!
Coolster 3150-DX2 . I have used the kick start a few times. The remote start / alarm system drains the battery. I don't think they come with remote start anymore. The new Coolsters come with LED head lights.
2023 Lifan Lycan 250 Chopper 2023 Venom Evader 2022 Lifan KPX250 2020 Kawasaki Vulcan S (Sold) 2004 Honda ST 1300 2016 Black Hawk 250 (sold) Keihin PE30 carb,125 main,38 slow.Pod filter,ported & decked head 10:1 CR,Direct Ignition Coil,15/40Sprockets,NGK DPR8EIX-9,De-Cat,Dual Oil Cooler,Digital Cluster 2016 Cazador180 XL 2014 Coolster150 JerryHawk250.com My YouTube Channel Last edited by JerryHawk250; 01-03-2017 at 08:26 AM. |
I own neither but I've researched both for Mrs 2LZ.
The Bull is shorter and slight wider from what I've read. The Coolster is longer and slightly narrower. I have a Tao Tao Rhino, and it's an decent quad but my choice for Mrs 2LZ will be the Coolster with the new front disk brakes. (DX3?)
I just went through the same process. I bought 2 Coolsters. No regrets.
auto choke
how do you like the auto choke? quick question, say i wanted to get an aftermarket Nibbi carb or any carb besides stock that has a manual choke, would you just zip tie up and cap the wire connector that would normally connect to the plug from the auto choke, and everything would be cool? or could this have some kind of effect on the CDI? but first off? do you like the auto choke? does it do its job? how do you know its working?
#6 | |
screws
hello...the screws are ant tamper proof for the EPA use a drill and remove them..
