actually no...
front wheel is stock speedo drive in the stock spot, stock spacer on the brake side, and then 3-5 washers to make it all line up proper (i forgot how many i used...LOL)
out back its stock right side spacer of the brake mount, wheel, cush drive, and then just the stock spacer on the left...i ened up using the ninja spacer, even though its pretty similar in size...LOL I paid for em i may as well use em...LOL and no washers out back.
its a fairly straight forward bolt up affair once you swap out the 17 and 15mm bore bearings for 15 and 12 mm bores to fit the axles...
the rear end, aka the wheel and cush drive i used:
one B15-86D-2RS
one LR202NPP
one 949100-3820/B382 AB
for the front i used a pair of:
LR201NPP
and all of those can be sourced from
ebay for around $10 each if anyone else is interested! i can shoot links if anyones interested...
