Old 02-15-2008, 07:26 PM   #1
ADAMnQuick300c   ADAMnQuick300c is offline
Lifan LF200GY-5, wont start
I was in the hospital for a month and in bad shape, when I came home recently I realized I left the gas knob in the ON position, so maybe it's flooded?
When I tried to start it, it just kept turning over and would sometimes start for a second then die.
The bike is brand new, just bought it in December and have put about 20 miles on it.
I havent had a bike in years so I forget how to get the bike running if its flooded, or maybe the 30 deg temp has something to do with it??
Battery is still strong though so I'm impressed there.
Someone plz help. Thanks!
-Adam
Old 02-15-2008, 07:37 PM   #2
madmaximum   madmaximum is offline
Send a message via AIM to madmaximum Send a message via Yahoo to madmaximum
try opening the throttle slightly while it cranks.
leaving the gas on shouldn't flood it, it's probably just hard to start from sitting a while and the cold temps. If it truly is flooded, open the throttle with the choke off and crank it.
Glad you recovered ok from your hospital visit
2005 RSX-200E
2004 Suzuki Eiger
1999 Arctic Cat 250
1977 Kawasaki KH400, aka Green Ripper
Old 02-15-2008, 07:48 PM   #3
AZ200cc   AZ200cc is offline
Probably just dried out from sitting have You tried a little starting fluid to get it going so the fuel will start flowing through the carb.
<br />2001 Suzuki DR200SE<br />1997 Suzuki RM250 YIKES<br />1995 Yamaha Breeze 125 daughters<br />1991 Honda XR80r Restored<br />maybe a 2003 Yamaha TTR90
Old 02-15-2008, 08:54 PM   #4
Savage   Savage is offline
If you're in cold temps it'll be a bear to start because it's so new and you probably haven't changed the carb C clip.
Make sure you have a fully charged battery. (get a cheap trickle charger if you don't have one) Pull the choke and keep trying.
If it still won't do it, face a hair dryer towards the carb to put the warm air in there.
Old 02-16-2008, 08:59 AM   #5
MATT   MATT is offline
may be worth your time to move the carb needle. It made a huge difference for me as far as starting goes. mine wouldn't start at all in temps below thirty with the stock needle set up
Old 02-19-2008, 08:43 AM   #6
fatboy250   fatboy250 is offline
Make sure to pull and HOLD the choke in the up position while you try to start it. This could be the issue.
2008 Jonway MC-70-150
2007 Roketa DB-07B (RSM-200E)
2006 Roketa DB-07A (RSX-200E)
1995 Kawasaki Concours (ZG1000)
Old 02-19-2008, 09:21 AM   #7
mrhyak   mrhyak is offline
If my bike has been sitting awhile and doesn't want to start I just give it a squirt of starting fluid in through the air filter and it usually kicks right over. If it continues to die, you have other problems such as a dirty carb?
1985 Kawasaki Tecate-3
1997 Ural Sportsman 2WD
1980 Yamaha XS1100
2005 TANK Trail 200
2009 Lifan LY110GY-3 (2)
Old 02-19-2008, 02:59 PM   #8
katoranger's Avatar
I have to do this on the really cold morning. The choke doens't fully operate otherwise.
Also make sure you didn't bump the kill switch on the handlebar. BTDT
Allen
Old 02-19-2008, 03:16 PM   #9
Allen
Yep
Old 02-19-2008, 03:17 PM   #10
katoranger's Avatar
I have done it more than once is the really funny thing.
Allen
Old 02-19-2008, 03:22 PM   #11
I did that also, I took out the spark plug and checked all the wires and the coil,...And than looked at the switch and cussed for about ten minutes.
