12-05-2016, 12:47 PM | #1 |
How much Diff fluid in a Roketa
I have 2005 Roketa RTQ-260 ATV. No fill level bolt in the rear diff. For much fluid do I use? Thanks for any help
12-05-2016, 01:32 PM | #2 |
Fill to brim of fill hole.
12-05-2016, 03:53 PM | #3 |
oil level
don,t you need room for expansion?>>>
12-05-2016, 04:13 PM | #4 |
The fill hole is only about half way up the differential. should take about 9 oz. if I remember right. If it is the newer differential Flashlightboy is correct.
Attachment 7910
2024 Linhai 300 ATV 4x4 2023 Lifan Lycan 250 Chopper 2023 Venom Evader 2022 Lifan KPX250 2020 Kawasaki Vulcan S (Sold) 2004 Honda ST 1300 2016 Black Hawk 250 (sold) Keihin PE30 carb,125 main,38 slow.Pod filter,ported & decked head 10:1 CR,Direct Ignition Coil,15/40Sprockets,NGK DPR8EIX-9,De-Cat,Dual Oil Cooler,Digital Cluster 2016 Cazador180 XL 2014 Coolster150 JerryHawk250.com My YouTube Channel Last edited by JerryHawk250; 05-10-2017 at 02:12 PM. |
12-05-2016, 08:28 PM | #5 | |
12-06-2016, 06:43 AM | #6 |
Okay , So your is like the one in the picture below. then fill it just above the axle.
2024 Linhai 300 ATV 4x4 2023 Lifan Lycan 250 Chopper 2023 Venom Evader 2022 Lifan KPX250 2020 Kawasaki Vulcan S (Sold) 2004 Honda ST 1300 2016 Black Hawk 250 (sold) Keihin PE30 carb,125 main,38 slow.Pod filter,ported & decked head 10:1 CR,Direct Ignition Coil,15/40Sprockets,NGK DPR8EIX-9,De-Cat,Dual Oil Cooler,Digital Cluster 2016 Cazador180 XL 2014 Coolster150 JerryHawk250.com My YouTube Channel Last edited by JerryHawk250; 12-06-2016 at 10:15 AM. |
12-06-2016, 12:17 PM | #7 |
This is the 1, top or bottom of the axle ?
12-06-2016, 12:27 PM | #8 |
Just above the top of axle. Its ok if you put more just don't fill to the top.
12-06-2016, 06:18 PM | #9 |
trailer hitch
Is that a trailer hitch??? nice.... thanks for the info .. makes it clearer on the top up
