Old 11-23-2016, 01:27 PM   #16
disturbed   disturbed is offline
no I don't think it will work in nj our dmv are assholes to put it nice
Old 11-23-2016, 04:05 PM   #17
pistolclass's Avatar
Tell them you had(or rented) a vacation home up there and you no longer have it.
Yeah I think NJ might actually be worse then CT as far as bureaucracy. I'm leaving CT and taking my money with me to NH. CT will soon be Detroit. I used to love CT now it is unbearable.
Old 11-25-2016, 07:28 PM   #18
so I know its prob in here somewhere but does anyone have the wiring diagram new harness is in but I have no previous harness to use I have stator hooked up rectifier hooked up solenoid hooked up battery hooked up but that's it I need a diagram for the rest of the plugs an wires all other parts for the connections are gone from bike so I need to know what to jump an what goes where to run bike
Old 11-25-2016, 09:32 PM   #19
humanbeing's Avatar
Old 11-26-2016, 05:53 AM   #20
Can i start an run with no relay
Old 11-26-2016, 07:34 AM   #21
humanbeing's Avatar
Just kick or push start it... This bike uses AC-CDI
E-start w/o relay = At ur own risk... Those sparks are HUGE...
1 of the experiment by a mechanic. GN125 uses TCI. When there's no reliable DC supply <battery fail/ stolen...> = Stunned in nowhere even push started it ... A capacitor is the saviour...)
Old 11-26-2016, 04:33 PM   #22
What wires do i jump i have no ignition switch no kill switch no lights or anything so jus want to make it driveable
Old 11-28-2016, 01:16 PM   #23
So i hooked up parts of harness hooked up coil jumped ignition switch but still have no spark
Old 11-29-2016, 08:06 AM   #24
pics
here the pics of how far I got with harness really need help with spar issue
Old 11-29-2016, 09:21 PM   #25
So i have now put a ignition switch in an on kill switch i jumped black an green together an still have no spark need help i also dont have a battery i dont know if that makes a difference any advice or help would be great
Old 11-30-2016, 09:58 AM   #26
2006 200cc
I have also hooked a battery to it an used e start still no spark
Old 12-01-2016, 04:42 PM   #27
Progress
Today i made some progress i got a multi meter did the test stator is good rectifier is good pulse coil is 👎
Old 12-01-2016, 07:51 PM   #28
zingshoen   zingshoen is offline
zingshoen's Avatar
i d try to set her up the way the diagram says, ie with battery. i dont think they run w/out battery. or capacitor. but that s another step, to replace batt with capacitor.
have u tested the new loom for continuity?
meantime, wire her according to the book. make sure you have good grounds from neg batt terminal to frame and bottom or rear of engine. without those it s useless.
as for cdi, you need the zong200 cdi - yamaha200TW won t work - other cdi s wont work - this has been established. if it is 2nd hand it may be dead. some last, some dont, it s a kinda weak spot in those bikes.
hope you can get it sorted! great solid bike, bit heavy, but pretty good once you strip excess weight.
1971 Garelli Gulp 50cc with open ports and 16 mm Bing Carbie + 1980 Honda XL 223 ZS + 2007 Zongshen LZX200G + DR400SM
Old 12-01-2016, 07:54 PM   #29
zingshoen's Avatar
of course an entire yam200TW electrical system could be transferred, but i don t think anyone has done that here. when spudrider put a TW230 motor in his zong, he used the zong stator.
Old 12-01-2016, 09:42 PM   #30
as of now the stator is fine rectifier is fine pulled it all apart pulser coil is bad that's my no spark issue so waiting on getting new one
