11-01-2016, 09:08 PM | #16 |
The results
I got the sprocket and jets in today. I installed the 110 jet first then swapped out the 50t with the 40t. It all went pretty good. I had to take off 2 links of chain. The results are great. Before with stock sprocket and jet 63 MPh at best now 74 MPh. It's perfect. Cruise 60 MPh with ease.
2023 Lifan Lycan 250 Chopper 2023 Venom Evader 2022 Lifan KPX250 2020 Kawasaki Vulcan S (Sold) 2004 Honda ST 1300 2016 Black Hawk 250 (sold) Keihin PE30 carb,125 main,38 slow.Pod filter,ported & decked head 10:1 CR,Direct Ignition Coil,15/40Sprockets,NGK DPR8EIX-9,De-Cat,Dual Oil Cooler,Digital Cluster 2016 Cazador180 XL 2014 Coolster150 JerryHawk250.com My YouTube Channel Last edited by JerryHawk250; 11-02-2016 at 07:33 AM. |
11-03-2016, 06:05 PM | #17 |
I'd been running 17/45 for awhile but changed to 15/45 this afternoon. Once I can give it a whirl I'll report my findings.
The 17/45 makes first gear just a little too fast for my uses, and it maxes out at 63ish mph at 6500 rpms which according to the specs is below the 7000 rpm max HP. Maybe 15/45 will be better on both fronts? |
11-03-2016, 08:37 PM | #18 | |
11-03-2016, 08:46 PM | #19 |
Is that speedo 63? or GPS confirmed?
11-03-2016, 08:52 PM | #20 |
GPS confirmed, and that is even with carb re-jetting. At stock gearing I was afraid to go past 50 due to the high rpm's on a fresh engine, so I'm not sure what I could have gotten.
My problem is wind. With a tailwind I can do 65+ but with any headwind I'm at 60. This weekend I'll see how the 15/45 does, if I can get into the power band without my hands going numb. |
11-03-2016, 09:05 PM | #21 |
I'm heading out tomorrow for the weekend of camping and trail riding. Going to see how the 15/40 works out. It still has good low-end power. Can still pull a wheelie in 1st. Lol. The 63 and 74 mph are both GPS confirm
11-04-2016, 08:00 AM | #22 | |
11-04-2016, 12:25 PM | #23 |
I am pretty much sea level Oklahoma. With 17/45 I can get to 60 easily and can even climb a moderate hill at 60, but it just has nothing left above 6000 rpm's. Maybe my exhaust has some bad welds and is extra restrictive.
I'll know more this weekend when I try a speed run with the 15/45 |
11-04-2016, 12:33 PM | #24 | |
2023 Lifan Lycan 250 Chopper 2023 Venom Evader 2022 Lifan KPX250 2020 Kawasaki Vulcan S (Sold) 2004 Honda ST 1300 2016 Black Hawk 250 (sold) Keihin PE30 carb,125 main,38 slow.Pod filter,ported & decked head 10:1 CR,Direct Ignition Coil,15/40Sprockets,NGK DPR8EIX-9,De-Cat,Dual Oil Cooler,Digital Cluster 2016 Cazador180 XL 2014 Coolster150 JerryHawk250.com My YouTube Channel Last edited by JerryHawk250; 11-04-2016 at 01:30 PM. |
11-04-2016, 02:26 PM | #25 |
Map says I'm 471 ft above sea level. I removed the endcap but didn't really notice a difference. I've seen some images of the inside of some exhausts and they looked horribly restrictive, maybe mine is.
11-04-2016, 02:49 PM | #26 |
My hawk been running very good with 17t-39t.Today I hit 72 mph @7000rpm with a fair amount of wind hitting my chest.Next week I'm going with 17t-42t and I think it will be the best combination for my weight and street riding.
80-20 tires 115-30 jets k and a filter ngk spark plug Pro-circuit t-4 exhaust 168 lbs. Mystef's accurate cluster. Side note:The Ducati s2r1000 has taken the back seat since I purchased the Hawk,it's a ton of fun for an affordable price. |
11-04-2016, 04:21 PM | #27 |
I never really paid attention to what it looked like on the inside. It was dark when I took the spark arrestor off and took off the end cap. Maybe take a long 1" rotary drill and bore a hole right through the center. I know sounds crazy but who will be the first to try it.
11-06-2016, 11:42 AM | #28 |
Tried the 15/45 today and RPM's at 60 aren't something I'm comfortable with for any sort of distance. Went back to 17/45. I think 16/45 might be the sweet spot for me.
11-06-2016, 03:16 PM | #29 | |
11-07-2016, 07:56 AM | #30 |
Got back from my weekend camping /off road trip. 212 mile over the weekend through trails and steep hills. The 15/40 combo worked perfect to me. The 110 jet really helped out. I'm 5'11" 180 pounds so not a lot of weight to carry around. There were a few hills that look like there was no way I can make that but went right up. I wish I would of had a helmet cam. We rode past midnight on Friday night, all day Saturday and night and Sunday. Don't know why my butts so sore lol. I'm not changing anything. it runs to good. I'm glad I mounted some bright LED's on my daughters side by side to light up the trails. Next on list are some LED's for the Hawk.
