#1501 | |
#1502 |
I just talked to them, it's 2355 shipped and the sale is only for in stock bikes. They got 1 black and the rest are white.
#1503 |
Member 2LZ would probably be a good person to ask. He has some recent videos in the video section of him riding around Volcano, California, on his TT. Of course, there are several others, too.
#1504 | |
The stock TT is a nice, mellow unit. Sounds like an old Honda 90. It did improve after a few hundred miles and it was starting to loosen up. You could start to feel a nice mid-range pull developing by then. These CG motors are TIGHT out of box but that's very common knowledge. The top speed, stock, is like other Hondoids, not that fast. They're geared to climb trees. I really like the TT250 and don't regret the purchase one bit. CSC has been nothing less than spectacular. It's a nice solid bike under you and comes with some really cool stuff the Hawk doesn't, like the 300 watt stator, USD forks, LED turns, etc. That said, if the Hawk is available to you in your state and you can get it plated, which it's NOT available here in CA, you may want to think about a Hawk or Storm and saved some $$$ if cost and budget are a super-concern to you.
#1505 | |
#1506 | |
![]() Quote:
Before doing cruising speed and top speed checking, You'll need to lub and re-route the speedometer cable or it will break within a few miles. Also need to learn how to convert KPH into MPH as the speedometer reads in kilometers. Next, remove the headlight assembly to make sure things within are routed correctly. Next, check the routing of the front brake line to make sure it's not getting pinched or rubbing to create a hole in the line. Next check to see if the shark fin is installed correctly to actually prevent things from being fed into the rear sprocket. Then you can check the tightness of all fasteners on the bike, and make sure wheel bearing are greased. Also check the engine oil level to make sure it's at the correct level. Another thing is to check to see if the exhaust pipe is correctly attached to the cylinder exhaust port. And finally make sure the spark plug in securely screwed into the cylinder head. So you can see there are a few things to check after rolling the bike off the pallet. ![]() |
#1507 |
At first I thought that you called him McLovin. I remember almost dropping my Hawk when I was trying the put the front wheel on just so I could roll it.
#1508 | |
#1509 |
That wouldn't work at 9:30pm. Their wives caught on a long time ago...
#1510 |
you mean the odometer? because the speed reads in MPH.
-whatever you do, just be awesome. - 2008 Kawasaki Versys - 2016 CSC TT250 |
#1512 |
I believe CSC will replace any TT250 owners KM calibrated instrument cluster for one calibrated in miles if you call them and ask.
Cheers, Dan K.
Dan Kearney - Black Hawk, Colorado, USA ![]() Dan's Motorcycle Blog - "Lost? I'm not lost. I'm just exploring. . ." |
#1513 | |
#1514 |
huh, never heard of that issue. mine read in mph for the first 8 miles till the cable snapped. the digital dash is so much better.
#1515 | |
![]() Quote:
![]() Also known as "miles 'til cable snaps"! ![]() |
