Old 08-05-2016, 12:08 AM   #1
rideabout   rideabout is offline
Broken weld on lower chain guide
Hello all!
Today I found that the lower chain guide mount welds had broken. Seems like an easy repair, I did send a note to CSC for advice regarding repair methods. Thought I'd pass this on to the group as this could be a corrosion problem if missed. Ride safe!
Old 08-05-2016, 12:24 AM   #2
Jay In Milpitas's Avatar
Looks like the threaded insert (riv-nut) came out?
Old 08-05-2016, 01:51 AM   #3
detours   detours is offline
detours's Avatar
Let us know what CSC recommends for the repair!
Red 5 standing by!
2015 CSC red RX3 with 19" front wheel, Shinko 804/805, skid plate, tall seat, 13T/45T sprockets, progressive shock, Winyoochanok windshield, GENSSI LED headlight, SW-Motech tankbag, Shorai Lithium battery
2014 Ural Patrol
Old 08-05-2016, 05:15 AM   #4
Hello Jay,
Yep the insert is held in by what looks like small welds on each side.
Old 08-05-2016, 07:43 AM   #5
CSaddict   CSaddict is offline
CSaddict's Avatar
Any local hardware supplier should have a replacement.
2016 CSC RX3 Ginger Edition
Check out my blog here:
https://www.facebook.com/My-CSC-Zong...0302595973417/
Old 08-06-2016, 08:28 AM   #6
madsocial   madsocial is offline
madsocial's Avatar
The bikes vibrate a lot due to running at high rpms. We should all probably get in the habit of inspecting things like this with every chain cleaning or oil change.
Cheers!
Rania aka madsocial
2016 Zongshen RX3 (CSC Cyclone)
Pay it Forward!
Old 08-06-2016, 11:10 AM   #7
Lee R   Lee R is offline
Lee R's Avatar
Yep, the high rpm vibes broke a light mount and wore a hole through a spare tube in the side case on mine.
Old 08-06-2016, 02:20 PM   #8
Ryan responded quickly and told me the recommended repair is to have the piece re-welded onto the swingarm and that this is an unusual failure. The repair will be covered under warranty. I'll let you know how it all goes with the repair and payment.
Cheers!
Old 08-07-2016, 01:37 AM   #9
rjmorel   rjmorel is offline
rjmorel's Avatar
If your not a welder, I'd try a muffler shop as they are used to welding thin tubing. rj
Live Zong, and Prosper
Old 08-14-2016, 02:07 PM   #10
swingarm repair
Hello all,
I've decided to cover the cost of the repair myself and not use the warranty. After thinking about it a bit I can't say for sure that an off-road impact/rock didn't result in this failure. CSC was quick to respond with warranty support but I think in this case I'll own the damage.
Be safe!
