07-01-2016, 10:44 AM | #16 | |
With miles, mine's getting better. Fires on the first push but still takes a few turns. As Ron B says, check your fuse connection and also, check your battery terminals for "clean and tight". I read that stalling could be caused by that on these, as well.
07-01-2016, 02:09 PM | #17 |
I remember reading something on RX3 Forums thread titled "Ignition Problems" Andy had his RX3 lose power and quit. I think he cleaned the ignition switch or something to that effect maybe its worth a look.
1973 BMW R75/5 1985 BMW R80 2013 Triumph Tiger Explorer XC 2015 RX3 Cyclone (White) 2015 RX3 Cyclone (Orange) 2016 Honda CB500X |
07-01-2016, 03:16 PM | #18 |
Mine would intermittently die while going down the road one day like I hit the kill switch. I could pull in the clutch and hit the starter button and get it running before loosing too much speed so road it this way for a couple of hours to get home. Got home and checked the battery terminals by accident and both were loose and would giggle enough to kill it . Tightened them and problem gone, rj
Live Zong, and Prosper |
07-02-2016, 09:00 AM | #19 |
Thanks guys for all the feedback. At the end of the day, someone put these bikes together so maybe it isn't a 100% and the amount of vibration coming off of them could cause anything to be loose at any time as well. I have learned that to be true with my Harley. I can't tell you how many screws I've lost and I've almost lost my exhaust ...haha..no lie.
Point being, guess this is a lesson to always double check everything. I am going to check the ignition switch, battery terminals, fuse and just any damn wire on the bike. It is possible during build, something wasn't pushed tight together, or with the mileage something came loose. Cheers friends! I'll let you know if I experience this again. Hopefully the bike starting right up at one push does get better. |
07-02-2016, 10:55 AM | #20 | |
And you were saying ? ? ?
07-03-2016, 03:01 AM | #21 | |
07-03-2016, 05:33 AM | #22 |
rx3 James had the bike stall wile riding turned out to be purple connector under seat was loose if it only happens when downshifting i would check valve adj. again the more you do it the better at it you will get
Peace and Zong Life
07-03-2016, 12:18 PM | #24 |
The plug under the seat I checked when i got the bike, only cause CSC said to do that in one of their videos, upon receiving your bike. I'll check it again though, doesn't hurt to check
07-04-2016, 04:54 PM | #25 |
Mine did this the last time I had a chance to drive it. Today after being on the road for three weeks I got a chance to change the oil and check the valves as part of my 2500 service. Both exhaust valves were too tight for my .04mm to fit under. My .03mm fit barely. I set them all to .08MM.
Eric 2016 CSC RX3 Sahara Orange |
07-05-2016, 12:28 PM | #26 |
6900+ Miles Still cuts off
I have checked the valves, Ok. When slowing down, less than 20 mph and coasting to a stop or about to turn, the engine just cuts off. I hit the starter and it starts immediately, and resumes riding like nothing happened.
This has happened many times, and seems worse in really hot weather.
Dave |
07-05-2016, 12:55 PM | #27 | |
07-05-2016, 08:16 PM | #28 |
Today was my first kinda worrysome moment with my rx3 at 2600mi. After work I started it up, and you know how a second or two into running it'll cut the idle speed down (depending on temperature of course)? Well it cut it...off. She started right back up and drove home fine. Hope it's nothing. It was also 100 F outside.
'16 Red RX3, K270's, 13t Front, Fog lights, Tusk Bar Risers (4K mi.) '82 Suzuki SP250 (11k Miles) '85 Honda Rebel 250 (Sold April 2016) |
07-06-2016, 10:15 PM | #30 |
weird that is it is happening to quite a few folks. I haven't rode it all week. I have buying buying parts for my other bike and having to drive parts home in the car. lol Exhaust, tires, fender...etc..etc.. The Harley is getting overhauled.
I'll take the RX3 out on Friday for a day ride and see if it happens again. |
