Old 06-03-2016, 11:05 PM   #91
mjstef   mjstef is offline
Hopefully Humanbeing can translate the headers for us.....
Old 06-03-2016, 11:31 PM   #92
OK, More measurement requests.......
Old 06-04-2016, 01:47 AM   #93
humanbeing's Avatar
轴套 collar |线 wire 长 length |接插器 connector |脉冲 pulse 信号 signal |油 oil 封seal 尺寸size| ** 类 Type 内innormalout 唇囗 lip| 备注 remark
Old 06-04-2016, 10:55 AM   #94
kohburn   kohburn is offline
kohburn's Avatar
Another long day today, but I have those measurements written down at home.
-whatever you do, just be awesome.
- 2008 Kawasaki Versys
- 2016 CSC TT250
Old 06-04-2016, 02:29 PM   #95
Thanks! I am hopeful we can get this addressed.....
Old 06-04-2016, 08:56 PM   #96
kohburn's Avatar
Originally Posted by mjstef View Post
one more thing, we need wheel hub sizes again from you, see first photo.
these are ~32mm inside diameter and 40mm outside diameter
- 2016 CSC TT250
Old 06-04-2016, 09:33 PM   #97
kohburn's Avatar
didn't have the rest written down so i had to roll the bike into the garage through the people door and pull the wheel again (did i mention how easy that is to do?)
- 2016 CSC TT250
Old 06-06-2016, 10:32 AM   #98
Kohburn, Sorry to be a burr under your saddle but the TT guys will love you for it.
"Our existing axle copper bush height is 24.00mm, but we can change from 24.00mm to 29.5mm according to your TT 250 sensor, and it takes about 2-3 days, if you can accept 24.00mm height, then we can send our existing sensor with 24.00 mm height right now. Please let us know your decisions.
Please see the detailed size difference. our size is marked yellow color after your number. we guess the difference is just measures tolerance between you and me."
Old 06-06-2016, 12:19 PM   #99
kohburn's Avatar
The rib on the casting is not critical. All of those dimensions should work fine except the bushing height. 5-6mm is a pretty big difference. I would have to shim it with washers.
if you want me to test fit one then just have them send the one as is. I can use a $0.60 bronze thrust bushing or a couple stainless washers to space it out.
would hate for you to get a bunch and have them not fit properly.
- 2016 CSC TT250
Old 06-06-2016, 07:16 PM   #100
simonjester   simonjester is offline
simonjester's Avatar
You guys rock!
2016 CSC TT250
Old 06-06-2016, 10:42 PM   #101
dpl096   dpl096 is offline
dpl096's Avatar
Originally Posted by simonjester View Post
You guys rock!
Yes they do
― Thomas Jefferson
Old 06-18-2016, 12:11 AM   #102
Kohburn, Any news? Will it work? If so i need to order a bunch. Lots of interest from TT owners.....
Old 06-27-2016, 07:40 AM   #103
Kdburtch   Kdburtch is offline
I was amazed at how easy this cluster is to install. Big thumbs up to mjstef for making this truly plug and play. I only bought this because my speedo cable snapped internally and after riding on this for a couple days I cant imagine going back. This is a much nicer cluster than stock and gives you all the feedback you need. I do plan on replacing the clamp on connector to the tach at somepoint, but its solid for now. I also really like having the gear indicator. Also my total time from walking in the garage to test ride was less than an hour! Great mod.
Old 06-27-2016, 08:09 AM   #104
kohburn's Avatar
guess I posted 2 other places but not in here that it works and is accurate to gps within 1mph
- 2016 CSC TT250
Old 06-27-2016, 11:59 PM   #105
ckrug4   ckrug4 is offline
The hawk tach cluster is awesome. I wish I could find a way to cut sun glare. The install was easy, the cluster works flawlessly
