Old 06-13-2016, 02:42 PM   #1
mq1991   mq1991 is offline
Lost exhaust header stud
Does anyone know where I could get the exhaust header stud? While I was riding today one of mine decided it didnt want to be attached to the engine anymore...
Would these work?
http://www.ebay.com/itm/1981-Honda-X...1XLSGB&vxp=mtr
Thanks.
Old 06-13-2016, 02:48 PM   #2
Sport Rider's Avatar
I opened this expecting find a picture of me!
Old 06-13-2016, 03:18 PM   #3
newrider93   newrider93 is offline
newrider93's Avatar
Y not just get a 8mm bolt?
My YouTube channel where you can check out my hawk and other cool stuff:
https://www.youtube.com/c/Andrew93
newrider93 AKA Andrew93
Old 06-13-2016, 03:34 PM   #4
Ugh, went out to see if the bolt would work and I see it actually just broke off in the head.
Any ideas on how to get that out?
Old 06-13-2016, 04:05 PM   #5
drill a pilot and use an ez-out might work.
Old 06-13-2016, 04:28 PM   #6
Azhule   Azhule is offline
"Alden Tools" (Pro Grabit and or Micro Grabit) works for me every time
https://www.amazon.com/Alden-8440P-G...dp/B001A4CWHO/
or
https://www.amazon.com/Alden-4507P-G...dp/B000Q60UOO/
If you have a Menards/Home Depot/Lowes, check those places first, they usually have these extractors in stock for less than Amazon
Old 06-13-2016, 05:13 PM   #7
I've had pretty good luck with the "Soak it in WD40 when warm, let it cool overnight, soak it in WD40 again...and get a small pick and try to spin it out" method. Many times they're not buried to the bottom.
Good luck!
Old 06-13-2016, 06:06 PM   #8
Mudflap   Mudflap is offline
My technique is to put a nut over the broken stud then weld through the middle with a wire welder. Then put a wrench on and remove it.
Old 06-13-2016, 07:34 PM   #9
Thanks everyone for the tips, I ran to the store and got a screw extraction set and it worked perfect.
So thankful, couldve been such a headache.
I ran to the store and got a stainless 8.8 bolt and put it in with a lockwasher and washer. So far so good!
Thanks again everyone!
Old 06-13-2016, 08:22 PM   #10
newrider93's Avatar
Mine did the same exact thing. Same bolt too. I used a M8-1.25 bolt with washer.
