Old 05-19-2016, 07:18 PM   #1
AdventureDad   AdventureDad is offline
AdventureDad's Avatar
handlebars?
So, got my new 16 rx3 in with the shorter handlebars and the bar ends. I want to install my Oxford heated grips and my barkbusters (taobao ones). Question ...will they fit? Or do I need to wait for the longer bars?
Old 05-19-2016, 09:30 PM   #2
dpl096   dpl096 is offline
dpl096's Avatar
I'm going to wait for the replacement bars...I don't like doing the same job twice if avoidable.
― Thomas Jefferson
Old 05-20-2016, 01:51 AM   #3
rideabout   rideabout is offline
Hello adventuredad,
I do not recommend mounting your heated grips on the shorter bars. I had trouble just squeezing on the stock hand guard bracket, the heat controller is much wider. Also, once your heated grips are installed they would likely be destroyed if you tried to remove them if you changed your mind. I replaced the short oem bars with Protaper evo adventure bars, I got tired of waiting for the csc replacement. The black looks great but they are not cheap, about $85. You will appreciate the extra room the wider bars provide for accessories as well as lever angle adjustments. Today I mounted acerbis wrap around guards. Easy installation, just cut a bit off your levers. Ride safe!
Old 05-20-2016, 09:08 AM   #4
Thanks for the heads up. I'll wait, or get different bars if the wait is excessive.
Old 05-20-2016, 11:13 AM   #5
CSaddict   CSaddict is offline
CSaddict's Avatar
The wait is already excessive.
2016 CSC RX3 Ginger Edition
Check out my blog here:
https://www.facebook.com/My-CSC-Zong...0302595973417/
Old 05-20-2016, 02:08 PM   #6
Rodtheviking   Rodtheviking is offline
Rodtheviking's Avatar
This ^
I will be ordering some bars next week,need to get this thing finished.
2016 CSC RX3 Silver
Old 05-20-2016, 11:20 PM   #7
dpl096's Avatar
Anyone given any thought to powder coating their CSC replacement bars?
― Thomas Jefferson
Old 05-20-2016, 11:56 PM   #8
Looking at these with the ATV high bend
https://www.rockymountainatvmc.com/p...term=tusk+chub
2016 CSC RX3 Silver
Old 05-21-2016, 01:34 AM   #9
rjmorel   rjmorel is offline
rjmorel's Avatar
Originally Posted by jontando View Post
I bought the ProTaper EVO Adventure bar. So now I have an extra 2015 OEM bar just sitting in my garage, staring at me.
want to sell them? I'm sure someone here will eventually fall down and go boom and need it. rj
Live Zong, and Prosper
Old 05-25-2016, 06:07 PM   #10
Anyone know the width and height of the "older" oem bars without the bar end weights? Or recommend some ? I want to add heated grips and my barkbusters ...maybe a cell phone mount...and I need the room. I want to keep the same height or maybe go a bit taller, but I need wider too. At least an inch?
Old 05-25-2016, 08:31 PM   #11
32 to 33 inch is what I figured, if they cut the ends off to fit the weights and keep the same specs.
I measured 30 inch to the new cut ends so a 31 1/2 inch or wider bar would be fine.
2016 CSC RX3 Silver
Old 05-26-2016, 07:33 AM   #12
thanks all, for the responses.
