04-27-2016, 09:35 PM | #1 |
Better Front Brakes for the Hawk?
Does anyone know of some better / replacement pads for the front brake on the Hawk?
My rear brake is awesome, but my front brake needs ALOT of force applied to slow the bike down. Thanks guys! Last edited by mq1991; 04-27-2016 at 10:33 PM. |
04-28-2016, 03:20 AM | #2 |
[For typical on/off chonda] https://item.taobao.com/item.htm?id=42455912424
Copmared http://www.chinamomt.com/product.php (the stamped model...) & http://ebcbrakes.com/Assets/ecatalog...catalogue.html We get the following(s) : FA056 (Circular) | FA165 (Hooked) | FA086 Name brand product that suits ur taste can found by those "EBC#"... --- Braided stainless steel brake line is a good upgrade...
04-28-2016, 08:11 AM | #3 |
Give the pads a bit more wear, they will improve.
04-28-2016, 08:58 AM | #4 |
Have you bled the brakes and swapped out to a 'known DOT brake fluid'?
I had some similar braking when we first got the Mrs. 'Bashan WILL', it took a few 'brake bleeding' sessions with new DOT4 fluid to 'stiffen up' the front brake, I also took the front caliper apart, clean/lubed/reassembled it to make sure it wasn't binding/stuck anywhere.
04-28-2016, 12:22 PM | #5 | |
I will grab some more pads as well. |
04-28-2016, 12:25 PM | #7 | |
Thanks! |
04-28-2016, 01:21 PM | #8 |
wonder if your pads are glazed and not bedded in properly.
-whatever you do, just be awesome. - 2008 Kawasaki Versys - 2016 CSC TT250 |
04-28-2016, 03:43 PM | #9 |
Can you sand them with sandpaper to restore them?
