Doh! Battery charging...
:oops:
Have you ever done one of those things that you just can't believe! You know, one of those things that make you think: "How in the heck could he do something so stupid!?" I certainly did one about 2 weeks ago. Yes I connected my battery tender backwards. The positive to the negative, yada, yada. My charger tried to tell me it was wrong. There was a little red light lit up on the front of it. I didn't look too close (needless to say). I thought it was just a power light. But a week after hooking it up I looked closer at the charger and realized that there are 3 lights. Yellow = charging, Green = charged, Red = problem. If you see red right away you should disconnect immediately not a week later. Bye, bye battery. I tried charging it correctly and it wouldn't hold a charge longer than about 20 seconds and not enough juice to even turn the starter. So I looked around and found one of these: http://cgi.ebay.com/ebaymotors/YTX7L...5213QQtcZphoto Even with shipping it was only $26. Works great. They have a couple left if you need a battery. And no, there was no alcohol involved in any of this story. I wish I could blame it on that. ![]() |
Roketarider,
You may want to try a couple of things. First the choke will sometimes pull back partially open by itself once you pull it up. Hold it all the way up and try starting. Second, the c-clip move to the last or next to last spot will help. Ours is on the last (closest to the pointed end) This has allow us to pretty much start without choking, even on cold days. We also, have the brass fuel/air mixture screw out about 2 turns.
2008 Jonway MC-70-150 2007 Roketa DB-07B (RSM-200E) 2006 Roketa DB-07A (RSX-200E) 1995 Kawasaki Concours (ZG1000) |
#4 | |
I looked at that screw, but have not adjusted it. |
Frostbite "The beatings will continue until moral improves" |
#6 | |
I never really had any issues with the previous battery. Also that is the battery for the GY-5. I believe the GY-2 has a different shape/size battery. |
#7 | |
Roketa DB-07A 200cc |
You had mentioned cold weather starting, that's why I suggested it. It has definitely improved ours.
#9 | |
There's a battery that WallyWorld sells that's ALMOST small enough for the Diamo's battery box. I put one in a Lifan some time back, just jammed it in. His battery box was busted anyway, so I ty wrapped everything since that's how he wanted to do it. The battery isn't sealed, so if you fall over, you could spill electrolyte.
The batteries I've gotten off Diamo, though, are pretty decent. The one I have in there now has been in there a year and is still strong, not bad. If they came without electrolyte, I'd order a supply of 'em for resale and use in case I need one, but batteries don't sit well once juiced. |
#11 | |
