Old 04-20-2016, 08:36 PM   #1
Sport Rider's Avatar
New trunk case installed
Givi style base plate that trunk attaches to. Exact fit for the bolts on the back end.
Old 04-20-2016, 08:38 PM   #2
One more
Old 04-20-2016, 08:45 PM   #3
dpl096   dpl096 is offline
dpl096's Avatar
What brand of trunk ? Looks good!
― Thomas Jefferson
Old 04-20-2016, 08:56 PM   #4
http://www.ebay.com/itm/351697333995
Old 04-20-2016, 09:13 PM   #5
dpl096's Avatar
Originally Posted by Sport Rider View Post
Outstanding thank you! I had a garage pro a few years ago and I liked its quality - how are you rating this one?
― Thomas Jefferson
Old 04-20-2016, 11:33 PM   #6
0utrider   0utrider is offline
0utrider's Avatar
Looks professionally installed!
Old 04-22-2016, 12:15 AM   #7
Very nice. Thanks for sharing the good information.
Old 04-22-2016, 01:32 AM   #8
To confirm, you're saying that the rack had bolt holes in the correct place for the mounting plate?
Old 04-30-2016, 05:59 PM   #9
Yep. If you are familiar with the givi mounts these are very similar. Perfect alignment with the 4 bolts in the back
Old 05-01-2016, 12:38 AM   #10
xposur   xposur is offline
is it exact fit but slightly angled? I have a give system on my other bike and had an extra a base plate laying around. The bolts line up, but not straight, they are off center slightly on my hawk.
Old 05-02-2016, 12:31 PM   #11
Thumbs Up
I want to second both the trunk AND soft bag setups. nothing beats a lockable trunk for quick and easy secure storage for around town, BUT, high mounting soft sides are the safer way to go off-road anyplace where a dirt/rock nap is conceivably possible, And some metal tube mounts for them on each side save the bike from a lot of potential damage.
One good fall with them on (and one less expensive trip for repairs) will make u a believer.
Old 05-21-2016, 09:16 AM   #12
simonjester   simonjester is offline
simonjester's Avatar
Can you recommend some high mounting soft sides?
2016 CSC TT250
Old 05-21-2016, 09:36 AM   #13
this one isn't a givi, but mounts in the same way. I was able to align the base with the bolt holes on mine.
Old 05-21-2016, 11:58 AM   #14
Are you able to get the seat off? I ended up using some large nuts to gain the space necessary to be able to remove the seat without first removing the base plate.
http://www.chinariders.net/showthread.php?t=16636
Old 05-21-2016, 12:16 PM   #15
No, I can't. thanks for the solution!!!
