Headlight Adjustment and Aux lights
Does anyone know if there is headlight height adjustment on our headlight assy?
Tonight was the 1st night I rode the bike at night The LED replacement works nicely, but is a little low The is alittle play in the assy, so I tilted up as much as I could, still to low for my feeling Also I got the 30 watt Aux lights that CSC offers I know they are somewhat pricey, but they work GREAT They really light up the road |
I believe the only adjustment is by loosening the 2 bolts on side of headlight and pivot it where you want the light then tighten it back down. I stuck some stiff foam between the headlight and top fender so it wouldn't vibrate back down. rj
Live Zong, and Prosper |
Like RJ said, you have to aim the whole assembly. I recommend a mild thread locker for those bolts. They can rattle loose on bumpy dirt roads.
That's what thought
I actually put a foam weatherstrip spacer between the headlight and fender also Glad I got the Aux lights to help light up more of the road |
Which LED headlight did you get?
Does it have low beam cutoff? How is the light pattern? The one I tried put out lots of light, but not in the center of the beam.
Dan CSC RX3 Cyclone, CSC TT250, Moto Guzzi V7 II, KLR650 |
I have the one that CSC offers
Can't say if it better the the original because I never had the original Light pattern was fine My issue was it was too low in front But once the driving lights are on the fill out the rest of the space |
