HELP!!!! no go issue on 125cc
Grandma and Grandpa got our boys a 125cc ATV. Not sure of the brand the tag info says:
SeaSeng , ZHEJiang Engine Family 6SSGX.125ACH It is a semi auto shifts fine from gear to gear no noises but will not drive. Any ideas on what it could be? I haven’t changed the factory oil yet but plan on it ASAP. Have pics of the engine as well if needed. There is a fill plug on the top of the clutch housing is it supposed to get fluids there as well? I thin so but the usless manual says nothing about it. It is a chain drive unit. ![]() ![]() |
Hmmmm, has the quad ever moved? If so how long was it ridden(hours) with the factory fluid? If the quad wasn't properly prepped( factory shipping oil not changed) being a wet-clutch tranny, the oil is critical to normal clutch operation, and if the quad is run without proper clutch-compatible oil, then it might be roasted. If the quad was dealer prepped and still under warranty, return it for service. If not, these are the things I would check.
2009 XR650L Big Red Pig Tusk bar risers 2007 X-Moto(Jetmoto) GY250 --mods--- 15/40 sprockets UNI Pod Filter 2007 Shineray TMS 200XYi--Betsy ![]() Betsy Mods:______________________ Acerbis DHH headlight FMF Powercore pipe Uni Pod Filter |
Thanks for the reply!!
It never moved I tryed once then let it be until I can figure it out. Plan on putting the new oil in 15/40 will get cycle oil for that. Does that cover the tranny or could it require another fluid as well. It has been over 20 years since I have delt with a bike engine so I am well a bit rusty. |
The tranny uses the engine oil, so it is important that you use an oil that's wet-clutch compatible. Since the quad has never moved, I suspect that there might be a clutch adjustment or mechanical issue.
OK thanks the folks got it off the net from powersportsmax so if it is a fairly easy fix it would be a lot easier then shipping it back out
